Technical Early PONTIAC V8 question
Discussion in 'Traditional Hot Rods' started by ratrod40428, Aug 26, 2019.
  1. ratrod40428
    ratrod40428
    I've done a lot of searching and read A LOT of posts but haven't seen my question answered, so here it goes.
    I have a 1955 287 V8 out of a Chieftain, its a bone stock engine and runs pretty good for its age. It does have a little smoke on start up and slight blow by until it warms up, I'm thinking its a stem seal/cylinder head issue.
    I have a set of 347 heads that were rebuilt a few years back for a different project. I know that the 347 heads will bolt on the 287 block and work. my question is, will i get any performance gain from swapping the heads? I did read that the exhaust ports are bigger so I'd have to track down some 347 manifolds. Other than that, simply from a performance stand point, is it worth doing?
  2. Using a graduated cylinder figure out the combustion chamber volume of each head.
    OR
    1955 287 192, 205, 216, 227 HP 518024 1.72 / 1.50
    1956 317 192, 205, 216, 227 HP 522010 1.72 / 1.50 Standard head milled 0.072"
    also provides 10:1 compression
    (285 HP engine) per Factory Bulletin
    317 285 HP (2x4V) 522845 1.72 / 1.50
    1957 347 227,244,252,270,290 HP 523298 1.88 / 1.60
    347 317 HP (F.I.) 52(4852) 1.88 / 1.60 Last 4 digits stamped on O.E. instal
    ratrod40428 likes this.
  3. Took a while....Yes putting on the 347 will increase your compression ratio
    Heads
    Year Model Head casting number Valve size (in.) intake/exhaust Comments Combustion Chamber cc
    1955 518024 1.72 / 1.50 73.0
    1956 522010* 1.72 / 1.50 192, 205, 216, 227 hp 69.6
    522845 1.72 / 1.50 285 hp (2x4v) 58.0
    1957 523298 1.88 / 1.60 227, 244, 252, 270, 290 hp 66.0
    52(4852)** 1.88 / 1.60 317 hp (F.I.) 66.0
    1958 528511 1.88 / 1.60 70.2
    X 528511 O 1.88 / 1.60 T395A 65.0
    XX 528511 XX 1.88 / 1.60 F.I. 65.0
    1959 531395 1.88 / 1.60 74.7
    X 531395 O 1.88 / 1.60 All 3x2 carb & T420A 68.6
    1960 536109 1.88 / 1.60 71.3
    X 536109 O 1.88 / 1.60 All 3x2 carb & T425A 66.8
    X 535461 O 1.92 / 1.66 SD*** ???
  4. Deuces
    Deuces
    Wow, no thank you for some good answers????....
    Unique Rustorations likes this.
  5. Install a PCV on your 287. I have two 56 316 Pontiac mills and a 60 389 in my hoard.
  6. stuart in mn
    stuart in mn
    Hold your horses, maybe he just hasn't come back yet to look for responses.
    ratrod40428 and Deuces like this.
  7. Unique Rustorations
    Unique Rustorations
    X2
  8. Bird man
    Bird man
    from Milwaukee
    I have '57 Manifolds :)
  9. ratrod40428
    ratrod40428
    Awesome! Thanks for the info. Time to tear into this thing and see what kind of trouble I can get it
