Early Pontiac alt/ps brackets
Discussion in 'The Hokey Ass Message Board' started by talltodd, Dec 8, 2014.
  1. talltodd
    talltodd
    from Parker, CO
    Is there anyone out there that makes alternator and power steering brackets for an early (1962) Pontiac 389 motor? I'm stuck and my search has turned up nothing so far...
  2. I will have to look, but might actually have at least the power steering brackets off a 63 Catalina with a 389 if that might work?
  3. talltodd
    talltodd
    from Parker, CO
    Yes, that should!
  4. I will try to remember to see if I have it. Shoot me a pm in a few days if you don't hear from me. ;)
  5. You can put an alternator on the generator bracket with a spacer on the lower bolt, have seen it done.
    They came stock with power steering, so that bracket should be easy to come by.
    Worst case, a swap to a newer front cover should allow use of most any Pontiac bracket on there.
