early poncho guys! (1949-53)
Discussion in 'The Hokey Ass Message Board' started by RawDeal, Oct 9, 2003.
  1. RawDeal
    RawDeal
    from Austria
    for those of you with SBC (or any V8), what rear axle do you run?
  2. Hepcat
    I've put a 307cu-in SBC in my 53 poncho, using the stock rear axle with no problems at all.
    A friend of mine ran a V8 pontiac engine in his '50 Poncho for years with no problems.
    I think you will find your stock axle will be strong enough.
  3. RawDeal
    RawDeal
    from Austria
    I run 350/350 with the original axle (1949), I'm not a racer rather a cruiser - I just wonder how much this axle can take [​IMG] and what would be a good replacement....
  4. Those 3rd members are the same from '37-56 and take a lot of punishment. I broke one in the folks' 55 0lds [same thing] when I was a stupid 16 year old but it took a full throttle neutral-drop to do it.
    Their weakest point is rear axle ball bearings and occasionally a rear wheel bearing seal will leak. Gotta remove the bearing to change the seal....
  5. chromedRAT
    chromedRAT
    shit...
    so you're tellin me that i didn't have to buy a 93 roadmaster rear end and suspension set (whole thing, rear frame and all) and weld it into the car, and that i could have spent the 300 on something else, and that i could have had my chassis done by now...
    great. fuck.
  6. Antibilly
    Antibilly
    This is a early Poncho!! Known as El Poncherello 33
  7. RawDeal
    RawDeal
    from Austria
    Thanx alot!
    yeah I know, I was tryin' to say early 50's poncho...
  8. Rainer
    Rainer
    DragLinkscc - don't be sooo petty [​IMG]
    hepcat55 - something wrong with yea rear end??
  9. RawDeal
    RawDeal
    from Austria
    no it's ok, just wanted to see what the others run
  10. 48_HEMI
    48_HEMI
    Hepcat is that your pontiac in the photo or mine? do you have any larger photo's [​IMG]
  11. Rainer
    Rainer
    this is one I could find fast
  12. Retroline
    Retroline
    I just dropped a 283 and glide in my '50 and had problems with rear uni joints so I put in a '55 chevy rear in a day and now have a better rear ratio. The stock Pontiac rear will hold up pretty good.The Olds has the stronger centre but the Pontiac were the choice axles.
  13. 48_HEMI
    48_HEMI
    Thats a twin to mine, I'm running the straight eight,split manifold and straight lakers on a 49 4 door fast back.with a 50 grill. black primer and very similar flames [​IMG]
  14. Hey Jim! That pontiac looks amazingly like yours. Just needs the purple velvet interior and a wheel/hubcap change.
  15. Fat Hack
    Fat Hack
    from Detroit
    Here's one of Heather's (Dollar For Dollar) car in Detroit at the Broken Dream Kruise...
    <img src=http://www.imagestation.com/picture/sraid74/pe1cec9238ae388e42b33bed521e41011/fb64e24a.jpg>
  16. RawDeal
    RawDeal
    from Austria
    @Jim: please post a pic of your car, now i'm curious...
    mine is a 49, but it already came with the '50 grille!
  17. 48_HEMI
    48_HEMI
    see what I can find [​IMG]
