Early OLDS rockets lets see some engines show us your goodies
Discussion in 'The Hokey Ass Message Board' started by backyardbeliever, Sep 26, 2007.
  1. Dr. Oldmobile
    Dr. Oldmobile
    Close Tony but, not all of them.
    Willis
  2. GOATROPER02
    GOATROPER02
    from OHIO
    You holding out on me Willis?
    Call me when your free
  3. Dr. Oldmobile
    Dr. Oldmobile
    New to the H.A.M.B. but here is a shot of some of my stuff.
  4. Paul
    Paul
    Editor
    Doc you're nuts
  5. Never2low
    Never2low
    Let me know if that Edmunds 2x2 is taking up too much room...:D
  6. Flathead Fever
    Flathead Fever
    from CA
    Here are a two 1951 photos of the Mitchell Muffler Pickup. Dave Mitchell replaced the flathead with 303 ci Olds in 1951. When I bought the pickup in 2004 it had a 324 Olds in it and a B&M Hydro.
    Jerry
  7. Looks like I am doing nothing new.
    I built a similar exhaust to this except I made my pipes swept back a little and the centre siamese port I used two by 1 3/4 and cut out the back of one pipe and overlapped them to pick up both ports.
    I have seen them done with 3 pipes down the side like sidevalve V8''s.I chose to do the double on the middle siamese port to make it look more like a V8.
    http://i219.photobucket.com/albums/cc214/32OLDSTER/MY HOT ROD PHOTOS/SWEPTBACKOLDSPIPES.jpg
    I hope these links work out. This is a site I made to share photos of my Hot Rod and some Hot Rod products that I have made.
    Tony Carter.
  8. Dr. Oldmobile
    Dr. Oldmobile
    Thanx Paul. You and Dennis Mothershed are in agreement. I do value and respect your opinions. ((<:
  9. In my 32 FORD roadster I am running a 371 Olds Motor,I am only running an alternator,no heater or Air Conditioning.
    So can I just block off the Heater hose outlet on the Water pump.?
    I would like to know if anyone thinks the heads would still cool OK with no water pipes connecting into the back top corners of the heads,near the Distributor.:confused:
  10. RoyalCrown32
    RoyalCrown32
    My 1953 303. Bored .040 over, Schneider cam and a NOS Fenton 2x2 intake.
  11. dsiddons
    dsiddons
    from Indiana
    Thanks for the screen saver.. Is that a Ross?
  12. GOATROPER02
    GOATROPER02
    from OHIO
    Yes sir,just a couple we built as of late.
    Tony
  13. GOATROPER02
    GOATROPER02
    from OHIO
    Both Rear holes are blocked when not using a heater.They are never connected together.Heads are usable on ether side of the engine as in no rights or lefts.
    And yes you can block off front outlet for the heater.
    Tony
  14. Thanks Tony,
    I have already made up the stainless plates,and polished the life into them and bolted them up.Cool another part of the Hot Rod Finished.
  15. What is the Gold Colour called on the 371 engines in this post.Paint number etc.
  16. Dr. Oldmobile
    Dr. Oldmobile
    V1147/5670-2166 Olds Gold metallic (EARLY) available from Bill Hirsch Company 396 Littleton Ave. Newark, New Jersey 07013 ph. 1 800-828-2061. I just ordered a quart. I've been using it for years and it is a perfect match.
    Dr. Oldmobile
  17. 38FLATTIE
    38FLATTIE
    from Colorado
    Don't want to hijack the thread, just a quick question.
    Will a 200R4 bolt up and work with a '62 394?
  18. GOATROPER02
    GOATROPER02
    from OHIO
    With my adaptor kit......YES
    Tony
  19. Paul
    Paul
    Editor
    posted this shot elsewhere,
    '57 Olds 371 backed by Muncie 4 speed, Olds rear...
  20. 38FLATTIE
    38FLATTIE
    from Colorado
    Paul, that thing is awesome!
    I've looked everywhere- does anyone know where to get a good HiPo cam for a 394?
  21. Dr. Oldmobile
    Dr. Oldmobile
    Ross Racing Engines Niles, Ohio. Tony where are you?
  22. BrandonB
    BrandonB
    from nor cal
    Here is a nice 371 J2 that a friend has in his 31.
  23. aerorocket
    aerorocket
    from N.E. P.A.
    As Dr Oldsmobile says, give Tony a call at Ross Racing you won't be sorry. I bought one from him a few weeks ago and am totally satisfied. Everything I have purchased there has been top quality.
  24. 38FLATTIE
    38FLATTIE
    from Colorado
    Thanks Guys. I talked with Tony this morning, ans he has everything I need.
  25. promachine
    promachine
    from chico ca.
    Nice looking blown rocket in a 34, current Hot Rod Deluxe magazine. Shines dad ownes it.
  26. 555impwagon
    555impwagon
    from milwaukee
    just dug this out of a semi trailer that came in for junk where i work
  27. Pete
    Pete
    '55 324, started with an Edmunds 2x2, went to a Cragar 4x2 then back to the 2x2.
    Car just runs better with 2 carbs.
    Pete-
  28. CGkidd
    CGkidd
    Damn it Titus those are some cool shit in your collection.
  29. 38 FLATTIE,I bouhgt all my 371 Olds parts from Egge Machining,but I had to get the Cam from,CAMCRAFT.As Egge had no stock at the time of shipping for my stuff to land here in Australia.
    CAMCRAFT said they have their own moulds and could grind my new cam to what ever specs I wanted from Mild to Wild.
    I suppose they have them for the 394 aswell you would have to try them.Good luck,
    Tony.
  30. grease
    grease
    This kinda looks like a modified Loghe funny car chassis from the 60's-70's.................... Am I correct?
