Technical Early Mallory distributor, model K, type 13, 4 cyl, Model A Ford
Discussion in 'Traditional Hot Rods' started by guam2250, Nov 29, 2019.
  1. guam2250
    guam2250
    Hello. This distributor has a vacuum operated "brake" on the lower plate with the centrifugal weights. Supposed to help retard spark at low rpm? Model B Ford had no brake, just centrifugal weights. What performance difference would there be if the "brake" was not used? Thanks
  2. Lil'Alb
    Lil'Alb
    from brier, wa
  3. guam2250
    guam2250
    Goodness, you are correct. Now I understand, and then some. Thanks so much! Basically, what I have here is an early step in the progress towards more efficient use of fuel, timing etc. For my purposes, of messing with some early modifications to stock Model A and B set-ups, I'm going to leave well enough alone. Not interested in changing too much, I'm going to stay with the Mallory model C, type 11 I found that employs centrifugal mechanical advance, retains the spark lever from the column, the large armored ign. cable, and won't be outrunning the mechanical brakes! Really appreciate the article. Thanks again.
  4. RussTee
    RussTee
    Great answer and in plain language
