Early GM aluminum V8's?
Discussion in 'The Hokey Ass Message Board' started by Dane, Aug 21, 2012.
  1. Truckedup
    Truckedup
  2. Dak Rat
    Dak Rat
    I drove a lot of thoes things (M114) when I took armour training at Ft. Knox KY in the late 60's. They did indeed have 283's in them, but I never noticed them being aluminum--maybe I just forgot.
  3. Devonrod
    Devonrod
    from london uk
  4. propwash
    propwash
    from Las Vegas
    derivatives of that GM aluminum 215 V8 were also used in the Morgan Plus 8 roadster and that 215 is a very popular engine in a specific class of hydroplane racing.
  5. wildcat465
    wildcat465
  6. 24riverview
    24riverview
    Used by Graymarine in the 60's also, sometimes in pairs.
  7. jimbousman
    jimbousman
    D&D Fabrication is still in business. Here's their contact info as well as some history on the motor.
    http://www.aluminumv8.com/tech/tech.htm
    I'm putting a warmed over version in my "A" coupe with a T5 and jag rear end. While it's not going to win many quarter mile runs, a 215 with the original Q4 four barrel will put out 200 HP in stock form. That's more than a most stock 283's or even an LM1 350 and a ton more than most hopped up flatheads plus it's 250 lbs lighter. Granted it's not for everyone but I'm gonna give it a shot.
  8. classic gary
    classic gary
    I'm doing the same thing. 'cept, 215, Muncie 4 speed, '57 chevy rear axle, Buick finned drums. Thniking the Offy 2 x 2 intake. Still collecting parts.
  9. Beau
    Beau
    I just picked up a spare block and heads for my 215 Olds. They have turned out to be spendy little buggers. Bellhousings are expensive.
  10. JCShiels
    JCShiels
    Sometime in the late 60's Hot Rod did a feature on a 215 into a Corvair. They used a reverse rotation cam. There is a Spitfire somewhere around west MI with one of those in it, I have seen it several times.
  11. slowmotion
    slowmotion
    A guy I graduated with had one (215) in a Baja type Beetle. Used to drive it to school. Cool ride, but don't think he ever got on it for fear of shredding the trans-axle. :eek:
  12. lippy
    lippy
    from Ks
    Had a friend had a vega with a 215 in it and was a sweet deal. On the M-114's we had in the Army in 72, ours were iron 307 chevy's. Lippy
  13. Bluedot
    Bluedot
    Had an Olds 215 in my last ride - '29 A CCPU - with a t-5 behind it. Like someone else said, it wouldn't win any races, but it was peppy and got on down the road with the twice pipes V8 sound we all love. And weighing only about 320 lbs, it made the truck steer like it had pwr steering.
    BTW, started with the orginal Rochester carb, leak city. Replaced with a Holley 390, which worked very well.
    Several have mentioned D&D. They are a wealth of information, and have lots of parts, new and used.
  14. momach
    momach
    Here you can see an aluminum 283 in action. Mid engine Corvair.
    http://www.youtube.com/watch?v=qPgI3FV-jqo
    go to the 3:00 mark for detail on the engine.
    What I'd give for that car... for at least a weekend of fun.
  15. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
    Hi Guys,
    Over here in the UK there are many guises of the Rover engine, as stated earlier in the thread there are also a multitude of cc available including 3.5, 3.9, 4.0, 4.2, 4.3, 4.4, 4.5, 4.6, 4.9, 5.0, if you have lots of money 5.2 is possible, and if money is no object Wildcat Engineering will sort you out with a 6.0 version.
    3.5 versions through to 4.6 versions are quite popular over here in pop's and rods's. I got one myself in my Model Y running on quad dellorto's.
    Cheers.
    Russ.
  16. CutawayAl
    CutawayAl
    from MI
    Yes, the VW transaxle is close to the edge with even a stock 215 or the related 198 V-6 and 225 V-6. Where practical/possible the Corvair transaxle is a better option for the engine.
  17. classic gary
    classic gary
    mmmm, small block chevy valve covers adapted to your Buick/Rover heads. You guys know more about hotrodding the 215/3.5,3.9,4.0, ect. engine than just about anybody over here, I think! Plug wires ??
  18. Devonrod
    Devonrod
    from london uk
    Plug wires- must have coil packs, dissy is there just to block the hole.
  19. tommy
    tommy
    In the 90s I did the exhaust on a turbo charged one in a 58 Devon. I think the frame was an MG. I have seen one in a Corvair also. The Devon was cool but not a very good build....except the exhaust.:D
  20. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Does anyone have a picture of the aluminum block 283 out of a m114? Some other internet sites and references say cast iron block. It sounds cool though.
  21. I seem to remember that Olds offered a turbo-charged version of this aluminum engine in their F-85. And if my memory hasn't totally failed me it was rated at around 215 horsepower which wasn't bad in a small car in the early 60's.
  22. Beau
    Beau
    In my reading the turbo version was kind of a turd.
  23. Devonrod
    Devonrod
    from london uk
    Here it is on film-----
    https://www.youtube.com/watch?v=mm4wlocZRz8
  24. CutawayAl
    CutawayAl
    from MI
    ....... depends on what you compare it to. While it definitely wasn't the fastest thing you could buy, it was a lot faster than the non-turbo versions of the same car, and a lot of other cars on the road.
  25. 22george
    22george
    from ohio
    I seem to remenber something about a guy who put the 215 in a homebuilt airplane - the tailwind. In a book about it they said you could cut the crank from a buick 300 and use sleeves from a pinto 4 cylinder to bore and stroke it to over 300 cubes
  26. Ebbsspeed
    Ebbsspeed
    Yes, you can cut down a 300 crank and use it in the 215 to gain some displacement. Not sure about the Pinto sleeves, but do know that there were some used in experimental aircraft, some direct drive and some with prop speed reduction systems. Here's one installed upside down, with funky rocker covers used as oil sumps.
    https://sites.google.com/site/tailwindn999br/olds-v8-engine
  27. Tritone
    Tritone
    And around 2000? a guy in the Bellingham WA area cut and machined 2-215's together coming up with an aluminum Buick V12! Watched/listened to it run at a boat club event; fabulous noise, virtually no flywheel so RPM's were instantaneous. Started and run from a laptop computer. I believe it was injected at that time......sure would luv to know where it is now! Anybody in the GNW?
  28. no.scar.no.story
    no.scar.no.story
    If I'm not mistaken, the engine in said vehicle is a 283 cid v-6 deisel...
  29. plym49
    plym49
    from Earth
    I've always wondered if one of these motors would be good in a Jeep. Should not be hard to find a 90s LR in a junkyard or on CL.
  30. jimbousman
    jimbousman
    Here's a chart with all the GM applications for the 215 aluminum v8.. Interesting that the '63 four barrel Buick version ran out @200 HP and the best the Olds turbo version could do was 215. Not sure what mine will do. I have a few tricks in mine like 300 heads, 300 crank, Kenny Bell cam and headers. Not a ground pounder but it's also almost half the weight of a SBC.
