Hot Rods Early Frankland quick change
Discussion in 'The Hokey Ass Message Board' started by JohnMorneault, Mar 10, 2020.
  1. JohnMorneault
    JohnMorneault
    So I just picked up an early quick change rear. It's only 2 pieces. No center section. Can't seem to find any info on it online. Thinking about using it for my Model A Roaster project. Its huge but looks really cool. Any info would be great. Model number? Diagrams? Thanks! IMG_20200306_184202_500.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    loudbang, 1947knuck and Lil'Alb like this.
  2. tractorguy
    tractorguy
    Is the "pad " for mounting the aluminum cover and holding the bearing and gears an integral part of the housing half or is it a "welded on" conversion......hope my question makes sense.
    There are lots of good quickchange folks on here as well as some Frankland foks. We ran several versions of Frankland center sections on dirt track cars in the 1960's......everything from weld up kits to aluminum center sections.
  3. seb fontana
    seb fontana
    from ct
    Post a pic from opp direction.
    loudbang and tractorguy like this.
  4. Marty Strode
    Marty Strode
    I'v got the twin to it, done by Jim Frankland, they started life as a Timken 3/4 ton. The welding on mine is beautiful ! IMG_4374.JPG IMG_4375.JPG IMG_4376.JPG P1010156.JPG
  5. tractorguy
    tractorguy
    See......I told you you'd have really smart guys come on......I'm not even done typing and you've got answers and pictures ! As Seb and Marty I'm sure would also mention......there were lots and lots of Franklands in many configurations from crude (I still have some of the exploded pieces on my "never do it again shelf").......to very nice later models with aluminum pieces and nice upgrades. If you need parts and pieces......there are probably lots of dirt track (and asphalt ) circle track guys with everything you need gathering dust in the corner. Have fun
  6. check out the "Quickchange" thread on here........
  7. Blake 27
    Blake 27
    This was my early Ford banjo V8 quick DSC03643-001.JPG change, which appears to share the same rear cover.
  8. JohnMorneault
    JohnMorneault
    It's an integral part. I'll take some more pics today! Thanks guys
  9. JohnMorneault
    JohnMorneault
  10. John, a local fella here and old time racer has a bunch of them and might be a good source for parts if you need anything. He mentioned the other day that he has to thin out his stock. If you need assistance I am certain he would help you out.
  11. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Very cool, put it together.....
  12. Soviet
    Soviet
    As Marty posted, what you have is a very early go at the quickchange, based on an original heavy truck Timken. I can't imagine there are more than a handful still around. Very heavy, but very cool to see!
  13. mickeyc
    mickeyc
    I have an early quick change, based
    on a 3/4 truck assembly. Cast iron side bells with a Frankland center section with a ratchet to facilitate
    turning. Aluminum wide five brake drums also Frankland. It looks like a beast and is HEAVY.
    I carried it into my shed many years ago. Now I cant even pick it up. I did really like to hear it scream and
    whine. Almost as loud as the motor! Was quite the
    sensory overload from the seat!
  14. Cliff Ramsdell
    Cliff Ramsdell
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You mention in the thread title that it is a Frankland. Got any good pics of the rear cover?
    Surprisingly, everything you need to use it is still available.
    I have a lot of good used pieces.
    Is the differential welded up? That is the most common problem. 'Lincoln Locker'
  16. JohnMorneault
    JohnMorneault
  17. JohnMorneault
    JohnMorneault
    Not sure if its locked up. Haven't messed with it yet
  18. JohnMorneault
    JohnMorneault
    Debating putting it in my A roadster build. Might be a little overkill lol. But it looks so cool!
  19. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The only drawback I see, is that it's pretty heavy. A lot of unsprung weight in a Model A.
  20. JohnMorneault
    JohnMorneault
    Picked up some drums and backing plates yesterday. The guy has another set of drums. I may grab them. Anyone ever run these buick style drums on the front of an A? I've got a 33 axle I'm gonna be using. IMG_20200313_151557_470.jpeg
