Early Ford Stock Hot Rod Front End: Axle Spring Spindles Juice Brakes Steel Wheels
Discussion in 'Parts For Sale' started by 29Coupe, Oct 11, 2016.
  1. 29Coupe
    29Coupe
    City: La Habra
    State: California
    Price: SOLD!!
    --SOLD--
    *EARLY FORD COMPLETE FRONT END FOR SALE*
    Includes:
    - 1928-1931 FORD MODEL A AXLE
    Spindle Bung to Bung centerline is about 51" (1928 thru 1931)
    Spring Bung to Bung centerline is about 36 -1/2" (1928 thru 1931)
    Spring Bung Height is 2-1/4" (1928 thru 1931 & 1937 thru 1948)
    - 1928-1931 FORD MODEL A SPRING
    - 1937-1941 FORD SPINDLES
    - EARLY FORD HUBS
    Complete with all Bearings
    - 1940 FORD JUICE BRAKES
    Studs shown are 5 on 5-1/2" Bolt Pattern
    Additional holes are for 5 on 5" Bolt Pattern
    Will require new internal hardware: shoes, springs, wheel cylinders, etc..
    - STOCK TIE ROD
    One Tie Rod End needs to be replaced
    The other side is usable
    - MODEL A WISHBONE
    Stock but can be made into Split Wishbones
    - STEEL WHEELS WITH TIRES
    Rims are 15" and fit the 5-1/2" Bolt Pattern
    Tires are rollers only.
    - FRONT STEER DRAG LINK WITH U-CONNECTION
    - BRAND NEW UNUSED SPEEDWAY 47" TIE ROD
    If you're interested, I also have a 4" dropped axle for sale THAT IS NOT PICTURED (1942-1948 Ford Passenger Car):
    Dropped Axle spindle bung center to center is about 50-1/2"
    Dropped Axle spring bung center to center is about 40"
    Dropped Axle height at spring bung is 2-1/4 inches (1928-1931 or 1937-1948 Ford)
    Thanks!
    Jeremy
    IMG_2103.JPG IMG_2104.JPG IMG_2107.JPG IMG_2108.JPG IMG_2109.JPG IMG_2110.JPG IMG_2105.JPG IMG_2106.JPG IMG_2112.JPG IMG_2113.JPG IMG_2093.JPG IMG_2094.JPG IMG_2095.JPG IMG_2096.JPG IMG_2097.JPG IMG_2098.JPG IMG_2099.JPG IMG_2100.JPG IMG_2101.JPG IMG_2102.JPG
  2. 29Coupe
    29Coupe
  3. 29Coupe
    29Coupe
  4. 29Coupe
    29Coupe
  5. 29Coupe
    29Coupe
    Also included:
    - BRAND NEW SEALED PAIR OF SPEEDWAY TIE ROD HARDWARE KIT 5/8"
    HEIM JOINTS #916-32501-1 (Not Pictured)
    - BRAND NEW SEALED SPEEDWAY STEEL CONE SPACERS 5/8" HOLE
    #546-4110 (Not Pictured)
  6. 29Coupe
    29Coupe
  7. 29Coupe
    29Coupe
    Price Drop!!! obo
