I'm looking for a replacement for the "c" clip that holds the column shift rod at the top of the column as indicated in the picture. I can't find a replacement listed in the catalogs. Is there an alternative I can use? Thanks
Clark,would a standard 'e' clip work?Let me know the shaft size it needs to fit over and I'll see if I have any that size. Mark.
Take a small gauge single strand steel wire and twist it tight, cut it off and bend it flat...will work find.........
