Technical Early 60' s 283 timing cover witg two timing tabs.
Discussion in 'The Hokey Ass Message Board' started by thomas.parker197, Aug 19, 2018.
  1. thomas.parker197
    thomas.parker197
  2. Fordors
    Fordors
    Some early 283’s only used the crank hub pictured, and then there was the small harmonic dampener that was also used. With the dampener you would need to trim off the lower tab.
  3. thomas.parker197
    thomas.parker197
    So it came like that from the factory?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  4. Fordors
    Fordors
    Yes, I believe it could be used with the early style plain hub, or the 283 sized dampener.
    thomas.parker197 likes this.
