Earlier Olds heads on later engines
Discussion in 'The Hokey Ass Message Board' started by 29hotrod55kustom, Dec 30, 2009.
  1. 29hotrod55kustom
    29hotrod55kustom
    so i am picking up a later 324/371 (many characteristics identify it as 324 but it has a 4" bore like a 371), the engine was apparently in a boat or something. i am kind of baffled, when it was picked up it had early 303 no-number heads and adjustable rockers on it. strangely (i didn't know this till i saw it) the pad with the ID code was between the #1 cylinder and the next back on the passanger side instead of between the last two.
    i digress, so assuming this is either a 324 or 371, what would have been the purpose of the poor flowing 303 heads and adjustables? (the motor has hyraulic lifters) secondly, on say a 56 324 or early 371, what would the pros and cons be of using the 324 #8 heads i have? i know the #10 324's supposedly have better flow, but what can be done to have the #8's match the performance of the later ones?
    thanks for any advice or help.
    Jr.
  2. 29hotrod55kustom
    29hotrod55kustom
    not so much on the help? one more time before i call it a night.
  3. MAD MIKE
    MAD MIKE
    from 94577
  4. adamabomb76
    adamabomb76
    from York, Pa
    If your motor was in a boat, and repaired like that back in the day, it was to make it keep running. The heads, #'s, and anything else is confetti.
    It's a good starting point.
  5. 29hotrod55kustom
    29hotrod55kustom
    well, from what it looks like there have been no repairs to it really, mainly it just seems for some reason or another someone had swapped early heads on to it (for unknown hop up purposes?). the fuel pump has been blocked off as well as the waterpump. bores and pistons all look VERY clean.
    one other thing im puzzled about is, on the bellhousing where the holes are that usually have like a mesh in them, have solid freezplug type deals in em, i suppose to keep water out since it was in a boat? anyways.. drank caffine way to late and cant sleep. rock me to bed hamb.
  6. 29hotrod55kustom
    29hotrod55kustom
  7. touchdowntodd
    touchdowntodd
    difference between #8 and #10 heads is minor, and you really gotta be movin some power to see a big difference..
    get rid of the 303 heads, none of those were good, and the stuff will bolt up to 324 heads the same..
  8. Bearing Burner
    Bearing Burner
    from W. MA
    49-56 head will interchange. 57 up wont.
  9. 29hotrod55kustom
    29hotrod55kustom
    here is the cylinder, can anyone tell me whats up with the part thats oblonged out. has this been bored and sleeved?
  10. 29hotrod55kustom
    29hotrod55kustom
    heres another pic of all the cylinder bores, and then another of the bellhousing. it has slugs in the vent holes instead of the mesh like my other block. so, the oil pan is not like the 371's with the weird thing that sticks outa the side, but it has a 4" bore... so, could this be a bored out 324 or possibly a 370 industrial engine?
  11. 29hotrod55kustom
    29hotrod55kustom
    anyone know whats up with this engine?
  12. thunderbirdesq
    thunderbirdesq
    Is the head gasket still on there?
  13. Paul
    Paul
    Editor
    what's the stamped number on the deck surface say?
    it's a crapshoot trying to guess what the history is on that engine,
    it's possible a 303 spun a bearing and a later replacement short block was used...
    all heads will bolt to all blocks,
    the crashes occur when large valve heads are put on small bore blocks
  14. 29hotrod55kustom
    29hotrod55kustom
    im a retard, its the gasket that has the oblonged area.. DUH me.
  15. 29hotrod55kustom
    29hotrod55kustom
    must be a '56 324. the 324/371 Engle i have slipped in and fits like a glove. as far as i know the 371's had a weird canister looking thing on the oil pan, does anyone know if a 370 had the same thing? also, i dont think 371's had the vent holes in the intregul bellhousing right? anyways, it would appear that this is a 324, as the cam fit fine but the lifter bores were to small for the roller lifters that go with the cam, but the lifter bores can be taken out to fit the roller lifters correct? so the roller lifters i have must go to a 57/8 371 i would have to assume because didnt the enlarge the lifter size in 371's?
    anyways, i put the timing cover from my 303 on it since it is nicer than the one that was on the new motor and already had the motor mounts and fuel pump block off bolted to it and slipped the cam and distributor in to check and make sure everything was kosher.
  16. 29hotrod55kustom
    29hotrod55kustom
    the number on the pad is V370693
  17. 29hotrod55kustom
    29hotrod55kustom
    up for sunday sunday sunday
  18. Paul
    Paul
    Editor
    if it were me,
    I wouldn't open the lifter bores up
    I'd to go with chevy lifters.
    save the 371 rollers for the next build,
    or sell them to me :)
    I'll see if I can't id those block #s
  19. Paul
    Paul
    Editor
    grabbed this from an earlier DON_WOW post
    in your thread dated 7-02-08
    49-303-8A1001 TO 8A193864 H PREFIX =HYDRA MATIC
    50 303-8A194001 TO 8A568689 H PREFIX = HYDRA MATIC
    51 303-8C1001 TO 8C287312 B PREFIX = STICK TRANS
    52 303-8R1001 TO 8R214478
    53 303-R215001 TO R549482
    54 324-V1001 TO V355083
    55 324- V400001 TO V983275
    56 324-A001001 TO A385513
  20. 29hotrod55kustom
    29hotrod55kustom
    odd, mine starts with a V but has to be at least a 56 because it has the larger cam tunnel.
