Hot Rods Earl Wade clevor motor
Discussion in 'The Hokey Ass Message Board' started by larry short, Aug 3, 2019.
  1. Look at the block right above the timing chain cover, if it’s a 302 or smaller version, the deck for the cylinder head will be almost level with the timing chain cover. If it’s a 351W, the deck will be approximately 1/2 or so taller.
  2. larry short
    larry short
    your welcome
  3. larry short
    larry short
    will do thanks much
  4. larry short
    larry short
    i do remember regular freeze plugs
  5. 41rodderz
    41rodderz
    from Oregon
    Yes:p
  6. larry short
    larry short
    i have a stack of them i leave them outside so they can age
    fauj and s55mercury66 like this.
  7. larry short
    larry short
    im not sure your wrong it only says firing order on intake we didnt check wires to make sure if that makes since
    Boneyard51 likes this.
  8. larry short
    larry short
    not sure if they interchange
  9. 41rodderz
    41rodderz
    from Oregon
    Only time I saw Dyno Don run he didn't need a high HP engine. Car went from trailer , red lighted and back in the trailer . It gave me a case of the "disappointments".o_O:(
  10. larry short
    larry short
    wow bad ass thanks so much for all the info. i cant wait !
  11. loudbang
    I forget which way it goes but look at the fuel pump shape at the timing cover. One is a C shape one is wider google it and from the shape you know if it's a 351 Windsor or Cleveland.
  12. Boneyard51
    Boneyard51
    We built our from a 351 Windsor and it has the regular looking fuel pump pattern. So the Cleveland must be the long style pump.
    Bones
  13. Cleveland has a “cast in to the block” timing chain cover. Windsor has a bolt on timing chain cover. The Cleveland has a flat cover over the timing “tunnel”.
    deathrowdave, fauj and loudbang like this.
  14. Relic Stew
    Relic Stew
    from Wisconsin
    The more I look at it, I'm thinking it's a 302 as well. The water pump bolt is right under the deck, and the corner of the head is too close to the distributor for a 351W. A quick identifier is that the intake surface on a 302 is flush with the distributor hold down. On a 351W it is higher.
    The head should have a 2 or 4 cast on the intake side corners, which will tell you the valve and port size.
    I've read that some of the late 351M/400 heads had no number.
  15. randydupree
    randydupree
    from archer fl
    turn the fan around.
    Randall and loudbang like this.
  16. sunbeam
    sunbeam
    Cleveland no coolant in the intake manifold.
    deathrowdave and loudbang like this.
  17. flamedabone
    flamedabone
    Thermostat on the intake manifold means 302/351 Windsor, but the big canted valve heads are 351 Cleveland or 351/400 Modified. Likely, this is a Clevor which is a 351 Windsor with Cleveland heads which was the "hot setup" back before there were plentiful aftermarket heads for Fords.
    But, what the hell do I know, I'm a Pontiac guy.
    -Abone.
  18. Marty Strode
    Marty Strode
  19. 6sally6
    6sally6
    Last time I saw him........'he beat the dog crap outta Da Grump'..stomped him.
    1972 Cocoa Beach area, in Florida
    One of them.".....Run Whatcha Brung and hope You Brung Enough".... match races. He hung around and signed autographs and "mingled" with a bunch of us sailors!
    That fella could 'row through some gears'!! This was back when the drivers would get out and "walk-the-track" checking for traction before the match race. I guess it was a lot of theater be we ate it up!!
    Hell far its been 40 years and I can still "see-it" in my mind's eye!
    Sorry for 'departing-from-the-subject'.:cool:
    6sally6
  20. kabinenroller
    kabinenroller
    Here is mine almost ready for the dual quad intake.
    ‘70 Boss block, Edelbrock aluminum heads, special pistons, bullet roller cam, Crane roller rockers, 289 HiPo distributor.
  21. gimpyshotrods
    gimpyshotrods
    You got that right. I had one customer with a 351C 4V Mustang, and another with a Cougar.
    Neither was a good street car. Both customers lived in a city.
  22. Marty Strode
    Marty Strode
    I had a Shelby dual 4 intake with 600 Holleys , and gear drive secondaries with squirters. Ran it in a Jeep with the engine pictured above. Jeep 1.jpg
  23. kabinenroller
    kabinenroller
    My intake is also a Shelby low rise, I will be running two Holley 390CFM with vacuum secondary’s. A couple of Stelling & Helling air cleaners. This should be just enough carb for this engine being it is just for street use.
    Deuce-Deano and loudbang like this.
  24. Boneyard51
    Boneyard51
    The firing order is determined by the camshaft. 302 and down had one firing order, 351W had a different one. But since the cams will interchange, the firing order only indicates which cam you have.
    Bones
  25. DDDenny
    Marty has heard me say this before but there is a good chance I was standing in that group of guys watching the spectacle, that Jeep/Boss motor was a handful.
  26. larry short
    larry short
    71
  27. RmK57
    RmK57
    Dyno Don was the 1977 Pro-stock world champion so it's a safe bet he's put more bowties on the trailer that you could count.
    loudbang and Boneyard51 like this.
  28. deathrowdave
    deathrowdave
    from NKy
    BF7F1E93-E76B-4F43-943D-0157F0463D82.png 7DF2BA88-AEBF-4189-A263-D2667FB1E8A7.png I have built a couple street boss motors ,through the years . 302 with 2v C or M heads , very impressive . If your ever working on C or M block be sure to install the thermostat limiter and correct thermostat or you will fight for the life of your engine to determine why it is overheating . This was the look on a Buddy’s after removing a Boss 351 C from his 71 Pinto for overheating issues . A 6.00 part was omitted by the machinist , a hot tank cleaning .
  29. Bandit Billy
    Bandit Billy
    Deep thought. I wish that was my user name.
