Hey all, Just finishing up and ready to set up my e brake. Since I have a spooled rear, couldn't I lock one wheel? In other words, one cable to handle instead of 2? I ask because I have such little space on the left side of the frame (battery box, pan-hard, driveshaft loop- etc). I know I am gonna get the hack and cheap comments, but I think its a legit question. Pork
shouldn't cause a spin (compared to having two brakes), because the rear wheels will both get the same (small amount of) braking action, because the spool locks the wheels together. Lotsa guys don't bother with the e brake at all, so you'd be better off than them. But most guys who do install it, do both wheels, so you won't be as well off as them.
Better than nothing. In Texas they require the E-brake to pass the state inspection. They recently changed the process so you have to have the vehicle inspected and if it passes they give you a letter to hand over to the DMV when you renew your plates. No pass, no plates. I am seeing more TH400s from trucks and motor homes being used as cores since they have a drum parking brake on the tailshaft. Solves a few problems.
Seems like I've seen sprint or midget circle track rears with only a single brake, mounted inboard on an open tube axle rear.
Are you planning on this single brake stopping the car in an emergency? Give it a try and see if it works. I bet it doesn't. I bet it also won't hold the car when parked on an incline.
Good question given the use of a spool, and well,answered. But another question comes to mind....curious why you are using a spool on a (presumably) street driven vehicle? That in itself creates it's own set of handling quirks and drive line stresses. Ray
You could always use a hydraulic parking brake that is spliced into the brake line that goes to your rear brakes, locking both wheels and saving you a little room. I've used them of few times on some off road vehicles I have built and have had good luck with them.
Because if he's using the emergency brake his hydraulic system is probably compromised or he'd be using the normal brakes
If your only going to run one e brake, install it on the drive shaft flange. Mopar used a drive shaft e brake drum for emergency and as a parking brake for years. If you mount a big enough one on the rear axle input shaft, it will stop & hold, or the rear axle assembly will be broken. A spool is going to suck for driving on the street. Gene
50 dollar posi. I know it will be a bear to drive, but it's a hot rod that will go out once a weekend with historical plates
I have a single pot for brakes and clutch (IH master 61) so if a line goes, I need an "oh shit" stick
Probably will. Gonna take on her maiden voyage without e-brake. and just take some more time to figure out this setup
Johnnyboy34 offered this http://www.controlcables.com/ and there is Lokar as well. I am just gonna order a kit and take it from there. All my lines are brand new and over clamped (although I did do all the flares on the car- 4 total).
