Technical Dumb question. .phaeton vs roadster difference?
Discussion in 'Traditional Hot Rods' started by JTW, Apr 22, 2014.
  1. JTW
    JTW
    I'm ignorant concerning these. What are the differences in 28-29 phaeton vs roadster? Can you change a phat to a roadster with quarter, and sail panels?
    Thank you guys!
  2. One is a two passenger, the other is a four passenger
    There are no sail panels (C pillars). And, no, you cannot.
    Cosmo
    Posted using the Full Custom H.A.M.B. App![/QUOTE]
  3. JTW
    JTW
    [/QUOTE]
    Any on else... I know the four door crap... anything is doable, let me re phrase... are the doors different length than the roadster doors. Sub frame Can be changed, quarters and C pillar added. I was just unsure about the door length.
  4. TERPU
    TERPU
    The P'ton is the same as a Roadster from the back of the front doors to the grill shell. After that it's a whole different animal. You will need P'ton specific pieces to make up the seat back to the rear panel. It'll be worth it though. P'tons Rule!
    But to make a P'ton a Roadster you will need to order some Brookville rear quarters and the whole ass end for a Roadster including the trunk lid or rumble. A new Subframe and viola you will have a roadster.
    But why would you want a roadster when you could have a P'ton ;-)
    Tim
  5. redo32
    redo32
    doors are the same
  6. It would be more cost effective to sell the phaeton body and buy a roadster body.
    Charlie Stephens
  7. need louvers ?
    need louvers ?
    Or ya build the Phaeton and haul around friends!
  8. Ok, you'll have a lot of trouble finding c pillars and sail panels for a roadster. :p
    You Might have to make those.
