on my wifes 64 t- bird when you put on the turn signal the it does not blink and the left brake light goes out . if the blinker is not on the brake lights work fine ..... what are the probable causes? and how do i fix this .
either flasher no good, or the flasher fuse is blown, or a wiring problem, or the turn signal switch is bad, or....
'64 Birds have SEQUENTIAL turn signals.... the problem is PROBABLY in the sequencing unit itself....try hooking up the turn signals "normally" ( NO sequencer in the circut) and see if the problem goes away .....you can buy electronic after-market sequencers instead of the mechanical ones the factory used if ya wanna' keep the sequence... jersey skip
Start by taking the two left side turn signal bulbs out and retest. If all other things clear up let us know........
http://www.tocmp.com/tOCMP/wiring/5765wiring%20diagrams/fordindex.htm Here's the wiring diagrams to prove it out. Stu
Pull the turn signal switch handle towards the steering wheel while the blinker is on. I've been through 3 of them on a 64 Chevelle column and that is how I tell if they are split.
