Technical Dual Carb Push Rod Issue
Discussion in 'Traditional Customs' started by Matt Davis, May 14, 2017.
  1. Matt Davis
    Matt Davis
    Hi there fellow Hamb'rs. I have put a dual carb setup on my 261 and needing to figure out what to use as a spring return on the pushrod that I had to build. I do not weld.... so I was wondering if there's any other options out there?
    Thanks in advance for any help!
    Sent from my Pixel using The H.A.M.B. mobile app
  2. Sheep Dip
    Sheep Dip
    from Central Ca
  3. Matt Davis
    Matt Davis
  4. treb11
    treb11
    What carbs are those?
  5. Matt Davis
    Matt Davis
    Carter Weber's from Tom Langdon's.
  6. Atwater Mike
    Atwater Mike
    These Carter Webers: 2 bbl, progressive. Throttle bores are 28mm primaries, and 32 mm secondaries?
    My wife's got one on her mildly hopped VW 'Cal bug', 1700 cc. Works great, I've used them on 1600-2000 cc BMWs.
    My son set up an intake with four of them on a SBC F.I. intake, with a flat plate for the carbs...large plenum underneath made for a 'satisfactory mix'...Love these carbs! They came on everything from BMWs to Pintos.
    If you use Matt Davis's locking sleeves, just file-notch the rod for the set screws. Excellent idea, forgot those were available!
    Matt Davis likes this.
  7. i would weld a tab, but a small hose clamp should work to hook the spring on.
  8. Matt Davis
    Matt Davis
  9. Drill a hole in it put a cotter pin on the hole and hook the spring in the cotter pin.
    mario711 and Matt Davis like this.
