Dry Lakes Racing Gear Ratios circa 1935-1949
Discussion in 'The Hokey Ass Message Board' started by Bullington, Nov 15, 2010.
  1. Bullington
    Bullington
    1. Northwest HAMBers
    I'm working through a project and was curious what kind of rear end gear ratios were available to the dry lakes racers during the late thirties and through the forties.
    I'm trying to estimate what some of the record holders were running for RPM. I have tire sizes and speed, but unclear on gear ratios.
    Here are some ratios I have found for that time period. (could be wrong)
    3.27
    3.54
    3.78
    4.11
  2. jagfxr1949
    jagfxr1949
    Bull, I know my old man had a set of 3.54 and 8.00 16 tires and twisted his flathead A-V-8 well over 5,000 in outlaw runs in about '42. I think he wounded the engine.
  3. TraderJack
    TraderJack
    3:27 was available, and also available was the overdrive real axle, the Columbia.
    some used 18" indianapolis tires and wheels, etc.,m
    Trader Jack
  4. Justin B
    Justin B
    i think halibrand started making quickchange rears in 46 or 47, there were others well before them as well as the mentioned columbia rear ends. the everyday racer just swapped out to larger tires once at the lakes, mostly using 18 inch wires or kelsey hayes high clearance wheels (divco) and indy tires or just the tallest tires they could find. one old timer who started racing just after the war and worked at a hospital told me they'd "borrow" the rear wheels/tires off the ambulance
  5. plan9
    plan9
    hey Jack, do you remember what year Fords came with the 3:27 ratio? also. was it fairly easy or common for a guy to locate a set of used Indy tires?
  6. RichFox
    RichFox
    A non-Hamb friendly car, (Packard powered) but. Some people still run old Indy tires.
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I feel like you didn't really see those indy tires show up a lot until the Lakesters became more prevalent but I know nothing since I wasn't born until 1982. It's a cool fact to know when Halibrand started making quickies since I was teetering on the idea of running one in my '33 eventually but I always thought they were sort of High Dollar for the day and I like the idea of building a car for the average dude from back in the day. I'll probably run the '39 rear with 3.78's as planned, but '32 18" wires might be an option maybe....
  8. seb fontana
    seb fontana
    from ct
    Post the speeds and tire size, then we can give you an rpm..Rough example: 29" tall tire, 3.78 gear = 4381 rpm @ 100mph.. not as much rpm as one would think..
  9. Bullington
    Bullington
    Thanks Seb I have the formula for getting RPMs. I'm wasn't clear on the racers gear options for the time period.
  10. seb fontana
    seb fontana
    from ct
    I think what I was saying is that if the speeds [what were the speeds in the years?] were around the 100 mph mark, and they wanted to be at the 5000 rpm level then the 3.78 or 4.11 would have been fine..I don't know how high they wanted to run the engines, which was your question.. and the most common [for Ford] rears was the 3.78 and I think it would have been acceptable..I read somewheres that Ford had even lower gears than 4.11; like 4.44, 4.57, 4.86 in cars that were delivered to mountain areas [maybe in just the v8 60 and 4cyl]..
  11. mart3406
    mart3406
    from Canada
  12. Bullington
    Bullington
    Found record times for 1949.
  13. sololobo
    sololobo
    What a cool lesson in land speed times. I love the story about using the ambulance wheels and tires, what a guys gotta do sometimes! Thanx! ~Sololobo~
  14. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    As a side note here, I was checking out Chet Herbert's Beast III at the Crouse shop in Colorado a couple of years ago after it had just emerged from hiding. At one point in its history they had installed a huge diesel (425 c.i. 6-71 GMC I think) with twin superchargers on a home made manifold. The engine was laying next to the car and it was huge…looked like it wouldn't even fit under the body…... Anyway, it ran a preposterous gear ratio/tire combination that would move the car something like 12 ft for every turn of the engine. The motor would only turn maybe a couple thousand RPM's but had enough torque to pull it close to 200 mph and set some diesel records for the day.....
  15. RichFox
    RichFox
    If you or anyone else likes it enough it's available for loan as a HAMB type club endeavor to take to the salt and run. Anyone contemplating such a thing would have to show up with a trailer that I will let my car and tires on. They should show up pretty early (Like around now) in order to get the between meets maintenance done and any changes to suit them. That's about it.
  16. 4t7flat
    4t7flat
    I know that Ford made a 3.54 gear in 1946. I just sold the gear set last year,and it came out of a 46 Ford half ton pickup,barn find. I am sure it was original,it had the Ford script logo. I have another 3.54 in my 27-T,that also says Ford on it. It came out of a 36 Ford hot rod that was built in the late 40's,early 50's. The guy from Yesteryear Ford told me that Ford built some cars in 35-36 with 3.54's to take advantage of the new smaller 16" wheels.
  17. plan9
    plan9
    that is a really cool offer. what category does it usually run under? (comp coupe, etc etc)
  18. RichFox
    RichFox
    It's a C/Classic Gas Altered with the Packard engine
  19. Bullington
    Bullington
    Here are some more speed records and their years.
    Schenck's Golden Submarine 118.57 mph (1940)
    Jack Lehman 123.96 (1942)
    Arnold Birner 124.65 (1942)
    Arnold Birner 125.69 (1942)
  20. Bearing Burner
    Bearing Burner
    from W. MA
    4.44 came in V 60 panel trucks. 3.54 is the lowest Ford torque tube rearend gear I have seen,
