Projects Drug home this Henry J project.....
Discussion in 'The Hokey Ass Message Board' started by Littleman, Oct 18, 2013.
  1. Panel Pete
    Panel Pete
    Nice, looking forward to seeing you whip her into shape.
  2. 1971BB427
    1971BB427
    from Oregon
    What a great place to start! I'm jealous too!
  3. fiat gasser
    fiat gasser
    Man, that's a pretty big car from what you are probably used to.:) Hope you can reach the pedals.:D lol
    Great find, I know you will make it beautiful.
  4. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I first cut out the engine saddle crossmember that had the engine mounts built into it....the body shop the guy had the car at modified them for the last owner since he sold the blown Nailhead and had them convert the mount to sbc.......but they did them crooked....I could see it was out by eye......so that had to go.....I then removed the very front frame crossmember.......The frame rails had a 1/4'' difference between the two.....after a few cuts.....I had it back to level.
    I bolted the new Abruzzi Turbo 400 trans w/ a trans brake I picked up this weekend onto the engine...and slid in the 5,200 stall converter I was also using in the Truck.....I moved the engine into position bolting the trans into its crossmember.....just to see were the engine position would land......It places #1 sparkplug about 6'' in front of the axles centerline.....which stinks.....I can use the 10% set back rule.....But that was the problem w/ racing The J's back in the day and class......They were a favorite because they are so light....They have a 100'' wheelbase which allows 10'' from the centerline of the axle to back to #1 sparkplug ..that puts the engine real far back into the car...and that is why most did not like them..........engine was in their lap.......
    I need to decide if I am going to move the engine back......I don't need to move it the whole 16'' I can per the rule.......not sure of the E.T. gain by moving it at all ?...sure the weight transfer would be much better....Just not sure how much of a difference it all would make.....I think it would handle better on the street moving the weight back some.....but not only are you having to alter the firewall, that affects the brake pedal and master cylinder, and the steering column as well.....I bet it would make more wicked thou.But I was not planning on all this..It looks like I can move it back another 3'' and not hit the dizzy........Littleman
    Uploaded with ImageShack.us
  5. LeadSledMerc
    LeadSledMerc
    Isn't that Jon's (superchargednailhead) old car he built here on the east coast? Was always a cool car!
    What a great start for a rebirth of the Henry J!
  6. 2dr_sedan
    2dr_sedan
    That's badass!
    What's the story, previous owner just gave up?
  7. 6t5frlane
    6t5frlane
    from New York
    Love me the Henry J's
  8. enloe
    enloe
    from east , tn.
  9. I know you are cool with building your own headers but maybe grab an off the shelf set and use those to determine your engine set back ????
  10. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Yes, this was Jon's car...three owners ago now......he is the one that saved it and brought it home after he found it in California....was found as an older dragcar.....He owned and drove it for a long time before letting it go..........Dave
  11. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Jon saved an old dragcar and rebuilt it......had it many years.....sold to a guy in Ohio, which I think was scared of it......sold it to another Ohio guy, he tagged the guardrail @ the Gasser Thompson meet earlier this year, he had the car at a bodyshop and got frustrated w/ the guy.He pulled the car and decided he wanted out........I am fixing and plan on running it hard......Dave
  12. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I squared up the front rails and tacted in the front crossmember tonight.......need to plate the area I cut on the rear of the front rails by the firewall........I really just want to build a new chassis...but am trying to refrain...and fix it....sucks...I just would rather do the whole thing....trying to treat it as if a customer brought in and said fix it..if I had a shop...I even used my mig welder tonight.....I bet its been a few yrs. since I fired that thing up...Dave
  13. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Pic taken by Bob after the Henry met the guardrail....
  14. Saxxon
    Saxxon
    Do you ever finish a project ?? (He asked knowingly)
    I'm waiting for Death's Doorstep to turn a tire in anger and you build the truck. You run that thing until you start to bend it... then you freak us all out with Bad Donkey/Half Evil and now the J ... Geez man... you're killing us here...
    Do I even mention the Divco ?
  15. Can one ever have enough projects ? :D
  16. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    So.......I need medication.................agreed..........Dave
  17. cody1958
    cody1958
    from wichita ks
    Pretty sick I like it!!
  18. Saxxon
    Saxxon
    I didn't say it was wrong ...
    The problem here isn't too many projects... it's too many kick-ass, uber gnarly projects that we all drool over...
    Like I said... not wrong
  19. powrshftr
    powrshftr
    Well said Brother!
  20. 1971BB427
    1971BB427
    from Oregon
    Did I say I'm jealous? Yeah, I'm still jealous of what a cool Henry J that is, and will be!
  21. powrshftr
    powrshftr
    I think the car that it's GOING to be is the really scary part..;)
    Scott
  22. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    First I needed to square up the front frame rails and get them level...Had to make some cuts to do it....I also removed the engine crossmember and front frame small square tube crossmember and replaced it w/ a tube.
    This is the original graph job....I was not sure exactly how it was all done, but due to some of my cuts...I decided to re-plate this area....to ensure it could withstand a wheelie landing or two.....
    Next I started to cut and shape the new plates, the outer frame rail plates are 1/4'' thick, bent and shaped them to the frame rear contour ect. for a tight fit.......tacked them into place.
    Then I made the pattern for the top plate and cut it out on the bandsaw and shaped it and tacked it into place on both sides..
    Starting to weld everything in now......Kinda rushing this ....I really should be working on the mid-engine car...Littleman
  23. willymakeit
    willymakeit
    Looks good. Quick question, when welding the plates on is there any advantage to doing plug welds in the center in addition to the perimeter welds?
  24. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I think it is stronger........I still need to tig the inside perimeter of my larger holes....and have made a special drill mill for smaller ones...so I can add more solid plugs if I want...Dave
  25. willymakeit
    willymakeit
    Thanks I appreciate it.
  26. luke13
    luke13
    looks tough and very smart!! weldin the holes increases weld surface area, will definatly increase stiffness,
  27. ModelAPunk
    ModelAPunk
    from Buffalo NY
    Thats gonna be one sick ride Littleman! I'm glad someone who will fix it got it. Cant wait to see the final outcome!
  28. Gizzy
    Gizzy
    from N.W,Ohio
  29. Rusty
    Rusty
    Looking good! Looks fast already!
  30. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    damn I like that . would love to drag something like that home.
