Dropping a 57-60 F100,whats involved?
Discussion in 'The Hokey Ass Message Board' started by HotRod60F100, Aug 2, 2010.
  1. HotRod60F100
    HotRod60F100
    Ok I wanna lower mine.I was gonna go the gasser route but that kinda look odd with the 57-60's imho. plus the front leafs are rusted and ones even busted. So how do I lower it? any help would be greatly appreciated.
  2. Daytona F1
    Daytona F1
    from Florida
  3. chaddilac
    chaddilac
    Camaro clip!!!
  4. X2
    Its not that hard to do. I used 77 front steer and it worked out very well.
  5. Kickstarter
    Kickstarter
    from NC
    Depends on how low you want it. Reverse eye springs will drop it about 2" You can get a dropped axle from Sid's anywhere from 2" to 4" I think. The rear flip the axle above the springs for about a 6" drop, you will need to do a c notch if you want any ride quality out of it.
    Axles......http://www.droppedaxles.com/FORD_AXLES.html#TXTOBJ7D81431412F231
  6. Kickstarter
    Kickstarter
    from NC
  7. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    put a dropped axle in it! its cheap, you have the same suspension travel and can be done in a day. I did it and cost me less than $600 to drop the front and rear Did a reverse eye main leaf in the rear and took out the shortest leaf as well. I love it!!!!!!
    Mono leafs break, front clips are a commitment and often require different wheels and cutting your frame, mustang II is sometimes a little lightweight for heavy trucks with big blocks.
  8. Larry T
    Larry T
    Mid Fifties make 3" lowered springs. Or a dropped axle. Or IFS (you might search Jaguar clip). Or........
    Larry T
    Mid Fifties springs are 53-56, I don't know if they'd work on 57's or not. Sorry bout that.
  9. HotRod60F100
    HotRod60F100
    ?? This is the Hamb,its an old truck and many folks on here have lowered 57-60 Effies,nuff said!
  10. HotRod60F100
    HotRod60F100
    Oh and thanks so far for the help guys,I think I'll go the dropped axle route though because I don't wanna cut the frame off and I'm trying to keep it close to stock kinda.
  11. ironfly28
    ironfly28
    from Orange, CA
    spammer alert!!!!!!!!!
  12. HotRod60F100
    HotRod60F100
  13. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Make sure to use the tie rod extentions that Sid has and he recomends a 7 degree wedge to tilt the axle back. I had to make some 3/8" spacers to extend the spring bolt so it would come through the wedge so the axle could locate again. For the steering arm on the spindle I had to heat it up and lower it (the same amount as the axle drop) to make it the same geometry as the stock setup (I dont have any bump steer).
    And if you want to put power steering go with the Toyota box. It bolts right in place where your ford box went and hooks up just like the original one. The only thing you need to do is cut the column off the ford box, secure it to the floor of the body and use a rag joint to join them together.
    For the rear when using the reverse eye main leafs I had to grind out the inside of spring holder (the front one with no shakle) to clear the leaf that was now ontop of the eye. The gusset in the mount hits the leaf just past the eye and could break the leaf. Make sure everything moves smothly and you will be fine! Its the best way to go you will love it!!!
  14. willymakeit
    willymakeit
    Jag front end. Possible the crown vic also. As far as gasser look, that is what won the craftsmanship award at the Show Me F100 this year 57/60 F100.
  15. metalshapes
    metalshapes
    Tech Editor
    Thats what I did...
  16. HotRod60F100
    HotRod60F100
    Cool got any pics of that particular truck?
  17. 510madmav
    510madmav
    cannot go wrong with the reverse eye mono leafs, just buy them, bolt them in and get it over with. super easy, quickest route. Sac Vintage.
