Technical Dropped timing gear on floor...still okay to use???
Discussion in 'The Hokey Ass Message Board' started by 1950fleetline, Jul 6, 2019.
  1. 1950fleetline
    1950fleetline
    While working in the garage today I dropped my timing gear on the floor, I can see a little damage. So should I replace or use this one. What do you guys think?
    Thank you for any suggestions, as always![​IMG][​IMG][​IMG]
  2. Casey Riley
    Casey Riley
    from Minnesota
    Carefully file the mushroomed spots out of the lands of the tooth.
  3. Once you file it, it should be fine. I would use it.
    Todd
  4. lumpy 63
    lumpy 63
    Why does the metal look so porous...?
    1950fleetline and INVISIBLEKID like this.
  5. 41rodderz
    41rodderz
    from Oregon
    Inferior metal. Crappy casting.
    INVISIBLEKID likes this.
  6. Tri-power37
    Tri-power37
    Yes it looks porous but I think it is just scratches from hitting the floor. I would file it also -but then I seem to like to do things that wake me up at 3:00 am.
  7. squirrel
    looks like dirt, not porosity, to me. But it's hard to tell without being there.
    1950fleetline and ottoman like this.
  8. 1950fleetline
    1950fleetline
    Thank you all for taking the time to look at the photos.
    Yeah it was real dirty from hitting the floor which really made it look somewhat porous in the photos.
    I cleaned it up and filed any burrs from the gear. I think I’ll use it. Really bummed me out to drop a new part on the floor like that!
    Thank again for the help!!
    Fordors, loudbang and Casey Riley like this.
  9. VANDENPLAS
    VANDENPLAS
    What’s that gear made of? Cheddar cheese?
    As has been said clean it up and use it.
  10. pitman
    pitman
    from Hampsha
    Was thinking you could test it in a partially assembled block. Bluing would reveal the clearance 'fit. First rotation trial may not need valve spring loading.
    1950fleetline likes this.
  11. Casey Riley
    Casey Riley
    from Minnesota
    More than just burrs. Make sure none of the profile of the cog has deformed into the V groove where it meshes with its mating part (chain, belt, gear). And definitely no high spots if its mating to a belt.
  12. squirrel
    it's a gear, not a pulley or sprocket
  13. 41rodderz
    41rodderz
    from Oregon
    I understand deformation from hitting the ground but to me that shows the material is soft.
  14. 41rodderz
    41rodderz
    from Oregon
    I would be interested how that gear ends up wearing.
  15. 500caddy
    500caddy
    If I throw away everything I drop I would spend a lot of time ordering new parts
  16. OLDSMAN
    OLDSMAN
    Having dirt on it after hitting the floor concerns me. Every time I build an engine the floor is so clean that you could eat off of it.
  17. Casey Riley
    Casey Riley
    from Minnesota
    What does that matter? It still mates with a belt, chain, sprocket, or another gear.
    Deuces likes this.
  18. squirrel
    Just that you don't need to be too concerned with it mating with a belt.
    It might not be as finicky as you think.
    ottoman and Casey Riley like this.
  19. pitman
    pitman
    from Hampsha
    A bit like setting up a ring-&-pinion, where the paste 'marks' indicate the mesh.
    Deuces likes this.
  20. squirrel
    Except that there's no adjustment, and you can't hear it. If it still has a little bit of backlash where the teeth got messed up, then your filing job is just fine.
  21. Deuces
    Deuces
    from Michigan
    I'd replace it with a new one....
    els, INVISIBLEKID and TagMan like this.
  22. Ebbsspeed
    Ebbsspeed
    I'm in the "file down the high spots and run it" crowd.
  23. TagMan
    TagMan
    File it and you might get lucky, but if you were lucky, you wouldn't have dropped it in the first place :D
    Seriously, there atr three outcomes if you file it and use it as is:
    1. It works fine.
    2. It has an annoying "tick" which might drive you nuts and affect the longevity of the gear.
    3. The gear has been streesed due to the impact and could fail & mess up your engine.
    For the relatively few dollars involved versus the possible cost of repairs due to failure and work to change it, why not just replace it ?
    1950fleetline and Deuces like this.
  24. I’d get a different one because that thing is way too soft not because it needs dressed.
    els, XXL__ and Petejoe like this.
  25. Doublepumper
    Doublepumper
    What do I think? I'd replace it. Besides the drop damage, looks like it is starting to wear from the looks of the striations on the tooth faces. I wouldn't try to save it....not worth it to me.
    Deuces likes this.
  26. Deuces
    Deuces
    from Michigan
    I'd sleep better at night knowing I did the right thing..... ;)
    VANDENPLAS likes this.
  27. partsdawg
    partsdawg
    from Minnesota
    Quite a few opinions and at the end of the day the only one that matters is yours.
    I’ve rebuilt engines in dirt floor sheds with used parts and others in clean shops with new parts. All ran fine. Never lost sleep over any build.
  28. alanp561
    alanp561
    No such thing as luck, it's all premeditated carelessness. I'm speaking from experience, you understand;)
    Boneyard51, Andy and Deuces like this.
  29. 6sally6
    6sally6
    Dropping it on the floor didn't seem to hurt it too bad but..............did you hafta smack it with a sledge hammer!:eek:
    Great Day...it must have bounced like a rubber ball!!!!! J/K:D
    I think a little work with a file and you will be golden.
    Is it a gear drive with a floating idler? I believe "Kong" Pete Jackson's brother-in-law perfected the idea of two different size wheels in the idler. Anybody wanna guess WHY two different size wheels are used?!
    6sally6
    1950fleetline and alanp561 like this.
  30. squirrel
    Those aluminum gears are indestructible, compared to the fiber ones!
    Sent from my Trimline
    TimCT, belair, 'Mo and 3 others like this.
