Technical Dropped axle needs a little help
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Jun 5, 2018.
  1. 31hotrodguy
    31hotrodguy
    Help! My dropped axle like it's owner is a little off. Approx a 1/4 to be exact. Can anybody recommend someone that can straighten it. I'm in Bakersfield .CA. 20180605_124817.jpg
    Sent from my SM-G550T using The H.A.M.B. mobile app
  2. Roothawg
    Roothawg
    Sid Drapal,
    Nostalgia Sid's
  3. 117harv
    117harv
    The inclination or is it bent?
    prewarcars4me likes this.
  4. 31hotrodguy
    31hotrodguy
    The inclination. It came out from under an AV8 that was built in the 50's and street rodded in the 80's. When the car was being gone through the owner chose to replace with a new axle instead of have this one fixed.
  5. 31hotrodguy
    31hotrodguy
    I sent an email to them a few days ago but hadn't heard back. Wasnt sure if he was still around. I'll probably just have to give him a call next time I have a day off.
  6. 117harv
    117harv
    The right side needs a bit more drop to get the inclination right?
  7. Bursonaw
    Bursonaw
    Joe’s Speed Shop had dropped my axle. He did a fantastic job and was very helpful. Very impressed with the quality and service!
    http://www.joesspeedshop.com/
    Sent from my iPad using Tapatalk
  8. anthony myrick
    anthony myrick
    from al
    Sid seems to be busy with a new building according to his FB page
    We had had an old dropped I beam straightened at a big truck alignment place a few years ago
  9. 31hotrodguy
    31hotrodguy
    Sorry, no. The driver side end at the king pin holes is approx 1/4 fwd which would technically give it a slight negative caster. Or at least I would think??
  10. 31hotrodguy
    31hotrodguy
    I heard Joe's speed shop is good. Aren't they both in Oklahoma?
  11. There is a man in cali that does good work.Hopefully someone here will know his info.
  12. fordcragar
    fordcragar
    from Yakima WA.
    Call a truck alignment shop, they might be able to help.
  13. Just found his info-Anson dropped early ford axels
    Greg Haynes,Auburn Cali.
  14. akoutlaw
    akoutlaw
    X2 ph# 1-916-997-7012
  15. Deescott
    Deescott
    If you have access to a hydraulic press, you can straighten it. That’s what whoever you send it to will do. Take your time and bend a little at a time.
  16. Use Anson.....Greg did this exact same thing for me and it came back perfect. I week turn around. He's in Auburn.....
  17. Tetanus
    Tetanus
    Do it yourself Like he said. The hard part is done,just needs to be tweaked in.
  18. Roothawg
    Roothawg
    He and Sid help each other out. They are both good guys.
  19. 31hotrodguy
    31hotrodguy
    Thank you everyone for the advice. There definitely a few options out there. I appreciate the help!
  20. chiro
    chiro
    My vote goes to Okie Joe at Joe's Speed Shop also. He did mine. Incredible knowledge and craftsmanship. He has the jigs and YEARS of experience.
    Andy
    31hotrodguy likes this.
  21. hotrodtodd1960
    hotrodtodd1960
    Bakersfield frame and axle should be able to help you out
  22. 31hotrodguy
    31hotrodguy
    Thank you for the recommendation. I might check them out since they are local.
  23. Try Ansen Axle in the Sacramento area. He's in Ford Barn a lot.
