Hot Rods Driving at night
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 11, 2019.
  1. 1946caddy
    1946caddy
    from washington
    Maybe this technology is available for 12 volts.
    3W JOHN and HOTRODPRIMER like this.
  2. Black_Sheep
    Black_Sheep
    It wouldn’t take much to make a template of your mirror and cut a piece of Lexan or plexiglass to copy the VW shade design.
  3. deathrowdave
    deathrowdave
    from NKy
    My OEM 32 mirror was made of a tinted glass , most of the silvering was gone . The replacement is clear glass and yes it is a BITCH at night x10 .
  4. Slopok
    Slopok
    Flamethrowers don't seem so stupid anymore now do they?o_O
  5. You ever notice they sell boxes of BBS at the Truck Stops. When you get a tailgater behind your rig you throw a handful of BBS out on the road. Its getting where I cant see that black pavement when its raining at nite and I meet oncoming traffic the glare blinds me. Run a vacuum hose into the inside. Plug it with a pencil. When you get a bright beam on your tail remove the pencil and stick the hose into a gallon jug that mostly gas but has about 25% diesel and outboard engine oil mixed in it. The thick cloud will shield you from there bright lights. and the willnot be able to see your taillights. Of course I would never do such things?
  6. Torana68
    Torana68
    from Australia
    People around here have those lights that melt ice cream at 5 miles ( not just the deer , kangaroos and wombats but highway patrol with reflective decalwork).
    I don’t need to see behind me in the dark outside city’s so I just point the rear view down at the floor, problem solved.
    Deuces, 3W JOHN and HOTRODPRIMER like this.
  7. TWKundrat
    TWKundrat
    Just pull over and let them pass...
    Then light 'em up with your "brights"
    chryslerfan55, Deuces, nochop and 4 others like this.
  8. While it does not address your inquiry about a rear view mirror, I will say that I have been driving with sunglasses on at night for years. They really help my old peepers.
  9. 325w
    325w
    from texas
    On my coupe I used a Ford day night mirror for about 55-6 I think. Did a little rigging to make it look nice. Worked great for me and gave better rear vision period. Had some ornate ribs on the front side.
  10. primed34
    primed34
    Check with a glass shop. I can't think of the name of the glass maybe something bronze. My inside mirror on my coupe has it. Stock mirror I got off ebay that some one had already fixed.
  11. BamaMav
    BamaMav
    from Berry, AL
    You guys talking about tossing out BB’s and such, that worked in the old days when headlights were glass. Now they are all plastic, and stuff just bounces off them. With the old sealed beams, one hit, air got in the light and it instantly burned out. With the introduction of halogens, that went out the window, they will still burn if they are full of water!
    With all that flat glass in your sedan Danny, I don’t know how much a day night mirror will help. The shade in the back window might be a good alternative. Look in the baby aisle at a department store and find one of those roll up shades they use to shade the babies with. I’ve got an old one in the semi I hang on the drivers window some afternoons, it really helps knock out the sun and you can still see through it with the tiny holes it has in it. Might be a pain to pull it down every time you want to drive at night, but when rolled up you’d never notice it.
    chryslerfan55, Deuces, nochop and 2 others like this.
  12. 03GMCSonoma
    03GMCSonoma
    Have you tried the yellow lens models? They cut down on the glare a lot plus they lighten up the darker surroundings so it isn't so dark. I have found they work great day or night. The style I wear go over my regular glasses. They have the side panels so the bright light doesn't shine in from the sides.
  13. stuart in mn
    stuart in mn
  14. RDR
    RDR
    HRP,
    This may not happen on your sedan but on my '34 Pickup when the brights are behind me, the flat windshield basically goes opaque and you see nothing ahead.....Have to crack open the windshield to angle the fools lights out of my vision....
    Deuces, Chili Phil, Chappy444 and 2 others like this.
  15. Maybe apply a little window tint on your rear view mirror-You wouldn't want a very dark tint-but it could be effective...and cheap.
  16. Merlin
    Merlin
    from Inman, SC
    My neighbor swears by the glasses version, been thinking about those myself.
  17. This is very similar to what I ended up getting for the '54 Ranch Wagon and it actually appears as though it could have been installed at the factory, slightly longer but it doesn't look out of place.
    As for the sedan it's to wide to fit in the the original position, I have the original style sun visors and they just barely clear the mirror.
    The Fulton style or the VW glare shield would simply clip on when needed and slid under the seat when not in use. HRP
    chryslerfan55, Deuces and 3W JOHN like this.
  18. Another thing to take in consideration and I'm sur the guys that have T's & A's will agree is the flat glass reflects, what comes in from behind you also reflects off the windshield, it's bad enough at night, worse yet if you get caught in the rain at night. HRP
  19. 208custom
    208custom
    I'm using one of the mid 50's Ford factory day/night mirrors in my 50 and looks great in there. May or may not look ok in the older cars. I found mine on the auction site and it seems to work good enough for me. 0EC53161-1693-47E3-A7B0-B721CB0D3726.JPEG
  20. low budget
    low budget
    from Central Ky
    Good subject but this turned out to be a little different than what I thought it was gonna be...
    I was just thinking the other day how cool it use to be, lone wolfin it back from a cruise night about an hour away, rollin down the highway with only my 55 gauge cluster glowin back at me, vintage headlights glaring ahead, summer night air blowin in along with the sound of a continuous mellow tone rumble coming from the exhaust,
    and thinkin to myself "this is the same view someone had all those years ago when this car was new"
    Weird how things change and how some things stay the same, maybe we would almost have to look at those same dash lights now differently than they possibly could have back then???....but only for a moment there....;)
    Dash lights at night would also be a interesting thread:cool:
  21. thekid1950
    thekid1950
    There's one in every crowd
  22. 3W JOHN
    3W JOHN
    Some people just like to complain.
  23. a boner
    a boner
    November, that was last year. This is now!
    Deuces and HOTRODPRIMER like this.
  24. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Honestly, what you are looking for is super hard to find... But if I was in your shoes HRP... I would get some windown tint laid on the mirror, Just about 50% or 35% vlt and it helps a bunch.... Its a little trick I learned a while back.... during the day its just like having tinted windows... night same just without the tint on the windows...
    Option B.... The sunshades that clip onto visors, were sold at the wall mart, you can probably cut one of those down to size and modify as needed to fit the mirror like your photo.... Will be tinted plexi at that point but same idea...
    Option C Get a piece of plexi from the hardware store, tint it, make little clips out of aluminum or stainless to go over the mirror like shown in the photo from earlier.
    End of the day its a good modification to do and I am right with you on the lights being too bright some times... My 31 was super low and I couldn't see anything behind me with headlights on behind me. I just took it as.... well someone is back there and if its the cops the color will change.
  25. It has been said in the past and bears repeating, There is probably nothing that hasn't been discussed time & time again on the hamb, I'm sure the member that pointed out the past thread remembered seeing it and felt compelled to comment and he was correct to a certain extent and from that post I did locate a day/night mirror for the '54 Wagon but never was able to locate anything for the Deuce sedan.
    In the end there is no problem. HRP
    chryslerfan55 and Deuces like this.
  26. 3W JOHN
    3W JOHN
    I used some of the dark tint on my mirror and it helped a lot.
    kadillackid and HOTRODPRIMER like this.
  27. Bandit Billy
    Bandit Billy
    Nuts and bolts bounce better and cops wouldn't suspect a thing seeing them trailing a HD :cool:
  28. porknbeaner
    porknbeaner
    In the sedan or even in a coupe I would consider some window blinds in the back window. It would be traditional in a sense as it was an option chosen back in the day.
    I remember my dad when I was a kid just flipping the mirror down in the roadster. But that is probably not desirable.
  29. Blue One
    Blue One
    from Alberta
    They’re just as stupid as they always were
  30. Mike Colemire
    Mike Colemire
    The last 3 years I drag raced I used the yellow shield on my helmet, I couldn't believe the difference. My Mom couldn't hardly drive of a night because of the bright lights would bother her, I give her a pair of the yellow safety glasses and she said it made a big difference.
    chryslerfan55, Chucky, Deuces and 2 others like this.
