Projects Dreddybear's Model A Coupe thread - DARTH WALTER
Discussion in 'Traditional Hot Rods' started by Dreddybear, Jun 26, 2008.
  1. D.W.
    D.W.
    from Austin Tx.
    Fuckin Rad dude! I am enjoying this.
    Lovin every minute of it!
  2. Dreddybear
    Dreddybear
    The column cost 9 dollars. Two lawnmower bearings and a length of steel tubing. The bottom bearing is sandwinched between two parts to create the sleeve that fits over the box (not fished welded and smoothed yet). The top bearing is snug in there but I'll stick a couple tacks on for good measure. I'm gonna make a bell to the back of the steering wheel. I was gonna Z the column over to the gauge cluster with an elaborate u-joint/bendy column setup but I like where the wheel sits and I dont wanna screw with steering stuff so I'm gonna move the gauge cluster to the left and use the old clock mount as the column hole in the dash.
    kidcampbell71 likes this.
  3. scottybaccus
    scottybaccus
    You made that entirely too easy. Thanks for difusing my problems for me!
  4. LORYDER
    LORYDER
    Awsome job keep up the great work.
  5. 60'shotrod
    60'shotrod
    Nice lookin' steeringwheel!I like what you're sayin' about not screwing with steering too much, you can't live without it!
    Nick.
  6. Very nice work !! And that dash is Retard-Cool !!! >>>>.
  7. 60'shotrod
    60'shotrod
    Is this akin to retro cool?:D:D:D;)If so I can just see the young hipsters getting down to the retard cool!!!!!!:D:D;)
    Nick.
  8. Racrdad
    Racrdad
    The dash is just too cool!!
  9. very cool car, love the dash.
    you gotta change the title of this thread though, I keep thinking you went back to the hemi, and I am always dissapointed when I see the caddy.
  10. Dreddybear
    Dreddybear
    Thanks. It wont change for some reason. I think it's too old..
  11. holeshot
    holeshot
    from Waxahachie
    damn bear...u some kind of metal god- branging that rust bucket back from the grave.i predict big things for ur future. tottaly awsom work. wait i dont talk like that.hell man iam 68 yrs. old you sir have inspired this old fart.keep up the good work and i know u will...just call me pop
  12. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Hey...You know those goofy push through wheel bullets from the 80's with the flat end So a tri bar spinner will bolt to it?
    they make really nice transitions from steering wheels to columns. and they are generally about 5 bucks each, So You can afford to buy a sacrificial lamb to start with, and a second one for "perfect."
    Ajax has em on the shelf behind the counter.:D
  13. striper
    striper
    The bell off the end of a torque tube works well too.
    Nice progress. Haven't checked in for a while. That dash is a winner.
  14. Dreddybear
    Dreddybear
    Ahhh! I'm on it. :)
    Thanks man! Gotta little more cutting to do, but I think I like it.:)
  15. tikidiablo
    tikidiablo
    from so cal
    I like the metal bell shaped covers for commercial fire sprinklers You see installed in ceilings. Old mom and pop hardware stores have the best old stuff for cheap.
  16. pyro3256
    pyro3256
    from OKC
    how about a more detailed write up of how you made the steering. like part numbers for bearings and how it all goes together. for guys like me on the short bus!
  17. dodgerodder
    dodgerodder
    Wow, I love the dash & wheel too. Whole car looks great. Plus the tags are entertaining as well, It's a win-win:p
    Dan
  18. MEDDLER1
    MEDDLER1
    Perfection man!i just got one and cant wait to get started.after this thread im not going to be able to sleep tonight.thanks
  19. holeshot
    holeshot
    from Waxahachie
    HEY DREDDYBEAR...u are simply the best metal worker. realize a group of the best! my meaning one can only be so good- and in my opinion u are just that! just call me pop.
  20. Dreddybear
    Dreddybear
    Thanks pop. Very flattering, but I am nothing compared to alot of guys on here. If you want to see a metal guy, check out this thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=163762&highlight=chrisp+36
    :D
    And if you want to see a metal god, check out this thread. This guy made the tools he used to make the car.
    http://www.jalopyjournal.com/forum/showthread.php?t=378992
  21. Dreddybear
    Dreddybear
    I moved the gauge cluster to the left a few inches so it's centered behind the steering wheel. I still have a bunch of finishing/smoothing/crying to do but you get the drift...
  22. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Looking Good DB!!! Keep chipping away at it.
  23. 60'shotrod
    60'shotrod
    I'm digging it!
    Nick.
  24. Looks sweet!! Makes me think of not using the stock dash...
    But I couldn't get it as smooth anyways. So I'd better stick with the stock one :rolleyes:
  25. Dreddybear
    Dreddybear
    Thanks guys. smoothed it out about as much as I want to. Now just gotta give it a little lead in a couple spots. On to the drag link. I think I'm gonna run it on the inside, I dont seem to have any clearance problems even with the suspension moving..
    Need a little more length (and the ol flipperoony)..
  26. Dude, the cops are watching you from across the street!!!
  27. R Frederick
    R Frederick
    from illinois
    How high is the pitman off the ground? Is it in the scrub line?
  28. Dreddybear
    Dreddybear
    Yes
  29. Dreddybear
    Dreddybear
    Just saw this..
    There are no part #'s on the bearings...but the steering column wasn't too complicated. I found a couple bearings that were flanged on the outside and had the right I.D of 3/4" and O.D of 1 3/8". Then I bought about four feet of steel pipe-I.D. of 1 3/8" which is the O.D of the bearings. Cut about two inches off the end and press the bearing in, then add the two inch piece back on the end. You can get it square by clamping angle iron to it and tack it back on now the pipe should have a bearing two inches inside. At this point you could cut a lengthwise slot at the end for a hose clamp or weld tabs on for a bolt. Then slip it on so the two inch extra piece slides over the box. Now get your length right and cut it to legnth and cap it off with the other bearing. Now all you have to do is find a bell for your wheel and bam!.. Ten dollar column.
    Shadow Creek likes this.
  30. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Fantastic work Paul
