dragster front axle caster angle
Discussion in 'The Hokey Ass Message Board' started by L79_Acadian, Aug 20, 2013.
  1. L79_Acadian
    L79_Acadian
    from canada
    Hi all,
    I am about to weld the radius rod brackets onto
    the axle for my slingshot dragster. What caster angle
    should the axle be set at?
    Thanks for the help..........
  2. RPM
    RPM
    We always used 10 degrees.
  3. H.G. Wells
    H.G. Wells
  4. paintcan54
    paintcan54
    On my K-88 it's so much 14 or 15 degrees that in a tight turn the front wheels flop over.
  5. dreracecar
    dreracecar
    from so-cal
    If you are useing late style front tires ie goodyears,hooseirs,M/T then 9-12* ,if you are using a tire with a round (motorcycle)style crown ie avons, chin-senn etc. then more caster is needed , no more than 20*
