Technical DOOR JAMB SCREW REMOVAL???
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, May 30, 2021.
  1. Nos1partstore
    Nos1partstore
    What's the secret to removing door jamb screws? these are from my 50 mercury
  2. 1935ply
    1935ply
    from peyton,co
    1. H.A.M.B. Chapel
    If the impact screwdriver won't get them, heat them red without melting and let them cool. Usually they will come loose then.
    loudbang, '51 Norm, mgtstumpy and 3 others like this.
  3. rusty valley
    rusty valley
    Or, weld a nut on, let it cool, and wrench it out
  4. Heat + impact driver = loose
    i7083, 1935ply, Blues4U and 2 others like this.
  5. dwollam
    dwollam
    I drilled about a 1/2" hole in some flat bar about an inch or so wide. Held it centered on the screw head and welded through the hole to the screw. Used the flat bar for leverage and screwed them out.
    Dave
    Like this!
  6. brading
    brading
    If you have got an Air Chisel Hammer you could use a Mayhew 37316 bit with a impact screw driver bit.
    vtx1800 and winduptoy like this.
  7. 51504bat
    51504bat
  8. jaracer
    jaracer
    Blues4U and kidcampbell71 like this.
  9. goldmountain
    goldmountain
    After you heat them red hot, douse them with water.
    Krash Vegas likes this.
  10. I wound up drilling mine out, refurbing the nut plates and using new screws. On the next one, I'll try the impact screwdriver method.
  11. Phillips
    Phillips
    Blues4U and loudbang like this.
  12. vickckik
    vickckik
    I have found that it sometimes works to try to tighten the screw first. With or without using an impact driver that, along with a bit of Kroil and patience usually works.
    loudbang and The37Kid like this.
  13. If a impact driver does not do it try heating up the screw red hot , then quench it with cool water. That will shock the area causing them to release. If that does not work then , Mig weld a large flat washer through the center of the washer to the screw , then weld a rod coupler ( looks like a long nut ) to the washer . put a socket and wrench on the assembly and will screw right out.
    Vic
  14. Corn Fed
    Corn Fed
    After SamIyam posted that trick years ago I made one and it worked wonders. Either buy one from Eastwood or make your own.
  15. Me too!. it has worked on those bastard tailgate hinge screws as well! The manufacturers in the 50's-70's must of had a "formula" for doing up hinge screws which meant that they were practically unremovable!
  16. KKrod
    KKrod
    I have heated them cherry red and then they can be screwed out with a large phillips. Do one at a time. The heat causes them to free up.
  17. Budget36
    Budget36
    Any rusted/stuck bolt I’ve used heat on, I always let it cool to the touch. Never tried to quench it. My thought is/was once I took the torch away the heat keeps moving and the bolt continues to expand. The once it contracts it breaks the bond.
    Besides, if I have a few to do, it’s a good excuse to grab a cold one while it cools off.
    i7083 likes this.
  18. Sporty45
    Sporty45
    I removed mine with one of these. Worked well.
  19. coupe man
    coupe man
  20. Happydaze
    Happydaze
    I've comparatively recently begun to have the use of one of these babies. Packs quite a punch with the impact action. Multiplicity of uses including small sockets. I have a manual impact screwdriver and air hammer but this driver has become first choice. Blasts huge screws into timber too. Good for gently stuff too. Wouldn't be without one now!
    Chris
    Sporty45 likes this.
  21. rdscotty
    rdscotty
    from red deer
  22. Fortunateson
    Fortunateson
  23. vtx1800
    vtx1800
    Studebaker's rusted badly..........the hammer driven device didn't work, heat and the air chisel with adapted screw driver bits as noted above worked very well. I did NOT use Phillips screws but went to an allen screw head and put anti sieze on everyone as I reassembled it so the next guy won't have so much trouble removing them.
    TrailerTrashToo likes this.
