I've got a '56 ford panel and the back doors are royally fubar'd. I was able to scare up another set of panel rear doors that are equally f'd up, but in different spots. It looks like I'm going to have to de-skin all 4 doors to repair the damage, and make one set out of the 2. Are there any decent tools to accomplish this? I'm looking to go a little less caveman than a flat screwdriver and a pliers. Anybody have any suggestions as to what will make this task a little easier? The local body shop supply places only have tools the cut the skin off, and i'd like to save mine.
bwahahaha. did you watch that first? if you're trying to salvage the doors I guess don't know of anything better--might add a spot weld cutter to the mix. If you're going to make completely new skins just run a grinder across the edge then clean up the leftovers.
Your going to have to cut the spot welds with a spot weld cutter, then unfold the skin, and reinstall/crimp it. http://www.tcpglobal.com/AutoBodyDe...No=STE+21890&gclid=COuflszPoLUCFa57QgodvjMAJw http://www.autobodytoolmart.com/min...p-13956.aspx?gclid=CNXZqPDPoLUCFUjZQgodKEUAcQ
running a da with 80 grit paper up and down the edge will make it a little thinner and it will bend right at the edge.
De-skin tool, scroll down to post number two... http://www.jalopyjournal.com/forum/showthread.php?t=550803
You can either drill out all of the spot welds or use a spot weld cutter and then pry up the flange to get the skin off. Whatever method you use, take care as to not put more damage into the skin. I made up some tools to help pry the skin, like the one below. I have several of these made from old screwdrivers. They work fine and I find other uses for the too.
Now thats what I'm talking about. Looks like you can buy something like that from eastwood for $30+shipping, but I like this better! I am trying to do as little damage as possible to both sets, as its about a 50/50 shot, which ones are the donors, and which are the fixers. I really won't know until they're all apart. Thanks for the help guys.
