Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. blair pletcher
    blair pletcher
    I had this FALCON back in the 80,s . had to sell it would love to know what ever happened to it , I lived in Taneytown MD , at the time
  2. gimpyshotrods
    gimpyshotrods
    Looks like EFI.
    The trad-police are going to have a fit.
    (My EFI system is here, waiting to go on.)
  3. Thanks. Only the number 3 cylinder exhaust runner needed messaging- everything else fit really well. I got more clearance on the driver's side header than I had with the cast iron manifolds....
    Thanks for answering all my dumb Sanderson questions via PM...
    I'm anxious to see your I6 EFI set up Gimpy...
    need louvers ? and loudbang like this.
  4. gimpyshotrods
    gimpyshotrods
    I am hoping to mount the T56 today, shoulder willing. Once that is in and I make a new tunnel, the EFI is on-deck.
  5. Falcon61wagon
    Falcon61wagon
    from Indiana
    Its been awhile since Ive done any work on the wagon and with spring around the corner I'm getting the automotive itch again.
    Gimpy can you explain why (again) you feel you made the wrong choice with the 3.76 gear set. Im swapping the 170 out for a 200 as well and want to make a educated decision on the which T5 trans to use
  6. Nailhead A-V8
    Nailhead A-V8
    I built a '64 convertable 15+ yrs ago(with a zillion hours just in the floor pans alone) I stuffed in a '69 351W mach 1 4v I used '63-5 falcon/comet motor mounts (which were rare 15+ years ago )and a maverick under pan crossmember and cut and welded a set of fox body 302 block hugger headers to fit I had no interference issues even with the 65 comet power steering rack and Box and a 66 mustang collar to eliminate the shift lever. I used the Granada/Monark disc brakes if I remember correctly there is a 3/16" height difference of the granada spindle to the falcon. I bought a pricey custom mustang tie rod end to mate the '65 p/s to granada spindles. used a Monarch hd sway bar. 65 Mustang pedals bolt into the stock pedal bracket and I made a T shaped bracket drilled for later trans mount pad bolted to the stock(leaf spring) to clear the linkages. I installed a Lincoln Versaille 9" (58.5")the spring pads are exactly the same width apart (43")but versaille has a larger centre pin the vers e-brake wont work if you bolt directly to the springs so I made 1" lowering blocks and put larger dowels on top and drilled the bottom the size of falc spring pin this set up allowed me to use the 14" x7" painted magnums w 225/60's with no rub. Spring plates must be notched and drilled for bigger U bolts. I used the '68 mustang dual master cyl. and fluid block from a 4whl drum maverick. Wired in the "duraspark" box and gm 1 wire alt. Depending on what year and also the year of engine (which side w/p exits) with slight mods to the rad support you can use either a V8 mustang or a maverick rad.
  7. gimpyshotrods
    gimpyshotrods
    The 3.76 gearset is only the wrong one for a 144, or a 170. The overdrive is just a little too tall for a stock setup, and just in reach with a better carburetor and distributor, all assuming a rear tire no taller than stock (about 23.2").
    The 3.76 gearset will be fine for a 200.
  8. gimpyshotrods
    gimpyshotrods
  9. Falcon61wagon
    Falcon61wagon
    from Indiana
  10. gimpyshotrods
    gimpyshotrods
    I believe so. 1960 were flat. 1961 were peaked. 1962+ were in the bumper.
    It has the wrong hood for 1963.
    Either way, worth it for parts alone, if you have the room.
  11. gimpyshotrods
    gimpyshotrods
    I have not gotten far past the machine work and one test fit, as I am working on-armed, due to a shoulder injury.
    Here's the first test fit.
    The extended pilot pushing needs a little shaved off, and then it should go right in
  12. Falcon61wagon
    Falcon61wagon
    from Indiana
    What's the plans with the left over t5 setup would you consider selling it?
  13. The turbo 2.3L T5 transmission works, too. The shifter is a little further forward than this looks, which might be a good thing for a bench seat. With the short, stock shifter it was a tad too forward, but I put on a big ol' truck shifter so I could shift with my arm through the sunroof.
  14. gimpyshotrods
    gimpyshotrods
    Me too.
  15. gimpyshotrods
    gimpyshotrods
    It's possible.
  16. Just tore into the rear frame of my 62 since it was not in the greatest of shape and have a replacement installed. Well long story short, pretty disconcerting when you sweep up the rear frame, but it feels better when there is a new piece ready to be put in. Need a new bumper on a side note.
  17. Falcon61wagon
    Falcon61wagon
    from Indiana
    For those of who who have a weber carb. Which idle jets do I need the big or small one on a dgav. Im going with primary 60 and secondary 50.
  18. gimpyshotrods
    gimpyshotrods
    Unsure on that one. I run a DFEV.
  19. Falcon61wagon
    Falcon61wagon
    from Indiana
    I was bidding on one at the time but didn't win. I was a little confused when looking online for the jets. It appears that the big or small idle jet will work for the dgv series but only the small idle jet for the df series. http://www.carburetion.com/Weber/weberJets.asp
  20. Falcon61wagon
    Falcon61wagon
    from Indiana
    Looks like the 74409.xxx is the primary and 74403.xxx is the secondary.
  21. Falcon61wagon
    Falcon61wagon
    from Indiana
    Does anybody know if an axle from a 73 6cyl maverick would swap out for the early falcon also was that year still 14" 4 lug rims
  22. gimpyshotrods
    gimpyshotrods
  23. gimpyshotrods
    gimpyshotrods
    Flippin' sweet!
    Leon Sandcastle likes this.
  24. Nice pun! :D but I totally agree it is a sweet set of pictures.
  25. 144 cubic inches of POWER!
  26. gimpyshotrods
    gimpyshotrods
    Don't disrespect the 144. With some small tweaks, they can beat most modern cars.
    need louvers ? likes this.
  27. Falcon61wagon
    Falcon61wagon
    from Indiana
    Spending some time today pulling off the exhaust manifold on the 200...and found a broken corner on the top front head bolt ugh... any chaces this can be salvaged? Also the manifold appears to have something strange going on with it. Any guesses?
  28. gimpyshotrods
    gimpyshotrods
    Heads are pretty easy to get. Look for an E0 (1980-end) head, and make a block-off for the EGR. They are the best flowing factory head, and have hardened seats.
  29. Falcon61wagon
    Falcon61wagon
    from Indiana
    Which cars? Hardened seats for the unleaded fuel. But the EO??
  30. gimpyshotrods
    gimpyshotrods
    E is the decade, 0 is the year of initial production, in Ford nomenclature. E0 means 1980, just like C0 means 1960, and so on. The letters started with new production after WWII.
    All 200's and 250's made in 1980, and later, should have the E0 head. That's the beginning of the part number.
    Yes, hardened seats for unleaded.
