Hot Rods DOES YOUR HOT ROD SQUEAK & SQUAWK?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Sep 8, 2016.
  1. My old sedan has been on the road for close to twenty years now and a few weeks ago I got the car up on a rack and greased everything and I used WD 40 on surfaces that doesn't have grease fittings but at slow speed going in and out of parking lots or driveways it's still squeaking & squawking.
    How have you guys addressed and fixed this problem? HRP
    dana barlow likes this.
  2. Turn up the radio, works for me every time.
    Bugguts, timwhit, Moondog13 and 3 others like this.
  3. chessterd5
    chessterd5
    from u.s.a.
    Actually, I enjoy it.:).
    HOTRODPRIMER and kiwijeff like this.
  4. Danny,In my stage of life,Its my Body that does all of that....especially the Squawking,,(Complaining)
  5. Blue One
    Blue One
    from Alberta
    It's old and flexible in some places and less flexible in others. Just like you ;)
    I bet you squeak and squawk at times too Danny :D
    HOTRODPRIMER and dana barlow like this.
  6. MAD 034
    MAD 034
    from Washington
  7. That must be what I have been doing wrong,of course I never install radios in hot rods. HRP
  8. Danny, you'd better check.....you might be riding a duck........
  9. b-bob
    b-bob
    I thought A's were supposed to squeek and rattle a little. My dad always always called them 'rattle A's'. But we do our best to cure them.
    falcongeorge and HOTRODPRIMER like this.
  10. On my 29 Roadster I had that problem and after making sure everything was lubed and greased and I still had a kind of groaning or creaking sound in driveways. Mine was a Glass body and I loosened the body mounts and greased in between the pads and frame and the pads and body with moly lube. It worked on mine. Someone told me it was the frame flexing just enough to make it groan. I always thought it was just because it was fiberglass , but in 4 years I never had a single stress crack. I sold the car about a year later so I don't know if the remedy is holding up.
    HOTRODPRIMER likes this.
  11. ratrod0
    ratrod0
    Motor is to loud
  12. 2935ford
    2935ford
    Yes, they are suppose to squeak, squawk and rattle.
    Both my roadster and pickup do that.
    Something is terribly wrong if they don't! :)
  13. Remove the mufflers and redirect the pipes so they dump out under the edge of the running board, or out the hood sides. It works like a reverse mute button, now the exhaust is all you hear. That how hot rods are supposed to be. lound and rowdy and no radios in any car that can be made more bad ass with the removal of fenders.
  14. DDDenny
    Danny
    You somehow come up with fresh subject matter every day (some call it filler), but not me.
    I'm kinda hoping your recovery from shoulder surgery drags out for a while but like me I know you're dying to get back in the game and start screwing something together.
    Now I know this is not quite HAMB "traditional" but you don't even know what squeeking and squaking is until you've had a full tube frame chassis'd car and EVERY moving suspension part is mounted in either urethane bushings or rod ends.
    Careful or you will remove too much tradition from that car by overlubing it.
  15. Mike51Merc
    Mike51Merc
    Oil your leaf springs. After sitting for several months, my leaf springs will squeak until the rust gets worn off, otherwise I spray lube them and the squeeks go away.
    HOTRODPRIMER and jeffd1988 like this.
  16. Thanks Denny,come to think of it it might be that dammed shoulder making all that noise!:D HRP
    34toddster and 56don like this.
  17. Rex_A_Lott
    Rex_A_Lott
    Does the 32 cowl mount to the frame on wooden blocks like the Model A does? Two of my A's have an annoying squeak, all I have to do is grab the windshield pillar and rock it from side-to-side and I hear it. I think maybe the cowl is moving, but I'm not down to taking it off to see yet.
    I like the taking off the mufflers idea.:)
  18. paul55
    paul55
    from michigan
    That's why I'm running open headers!
    HOTRODPRIMER and scrap metal 48 like this.
  19. Blues4U
    Blues4U
    from So Cal
    Yeah, as I've worked to quiet down the exhaust, and quell the rattles with weather stripping around the doors, I've started to notice the squeaking that I think is the body panels moving against the wood. I've tried to tighten the screws, but they are seized tight, can't turn them at all to tight or loosen them, so I"ll have to cut them off and replace them if I want to try to get rid of the squeak. It's not bad enough at this point to make me do that, so I tend to ignore it and enjoy the drive.
    And no radio for me either (if I put a radio in it, I would have to crank it up so loud to hear it, it would cause hearing damage!)
  20. steves29
    steves29
    I regularly tighten every nut on the woodwork that I can get at. The body to frame bolts will work loose a bit too.
  21. steves29
    steves29
    I got to thinking bear claw latches may tighten up the body twist a bit.
  22. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Actually I've found that WD-40 is not a great lubricant.
    From what I was told when they were developing it, it is a water displacer!
    It supposedly is made of some sort of fish oil, or so I was told.
    I have found that garage door lubricant is quite good for lubricating misc. joints and connectors.
    KK
  23. low budget
    low budget
    from Central Ky
    Arent you suppose to be living it up at the shades, What are you doin here?:D
  24. b-bob
    b-bob
    Speaking of mufflers, the two worst rattles are the mufflers themselves. If i thump on them there is a tiny sounding rattle. They only have one season them, so they shouldn't be falling apart inside.
    I had the car up on stands and went from one end to the other, thumping on everything and was able to eliminate most of the others. Oh, and that damn little round cover over the crank hole on the rad shell, a piece of double sided tape solved that one.
  25. My coupe makes just as many noises as I do, just louder when the engine is running.:D
  26. Raiman1959
    Raiman1959
    The only squeak now in my 2 road-worthy cars....is when my wife rides with me, and informs me I took a corner just a little to fast she hadn't seen coming....she then reminds me she isn't gonna sing ''dead mans' curve'' to the sound of my exhaust roar either! The ''rattling'' part is when I gotta climb over the doors to get out!:confused::oops:....then "I squeak"!:rolleyes:
  27. Merlin
    Merlin
    from Inman, SC
    More like not loud enough.
    Every hot rod I've owned through the years has squeaked. That don't bother me, it's when the banging starts that bothers me.:eek:
  28. jim snow
    jim snow
    Yes,and it is very comforting and familiar.Feels like home. Snowman
