Technical Does your hot rod or custom ever bottom out?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 18, 2021.
  1. BamaMav
    BamaMav
    from Berry, AL
    Nope, mine has never scrubbed or bottomed out. That is, until I changed one side of the exhaust for the SBF from the SBC layout....
    Going to have to reroute it higher than the wishbone in that side.
    But as to the original question, no, the suspension has never bottomed out, but one exhaust pipe has drug once.
    Deuces and HOTRODPRIMER like this.
  2. BLACK STUDE
    BLACK STUDE
  3. Elcohaulic
    Elcohaulic
    I use these between the frame and the chassis. They are designed to get more aggressive the more weight is placed on them.. front passenger side tie rod end.JPG
  4. 3W JOHN
    3W JOHN
    Yes,the 40 pickup did a lot, I added a additional leaf back to the spring pack that the previous owner removed, the truck rides a little higher but does't bottom out anymore.
    HOTRODPRIMER and Deuces like this.
  5. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Of course mine do! They are customs! As we say in the shop "It's the price you pay, to be cool!"
  6. I think on my 39 Ford the wishbone is hitting the frame before the axle hits the bump stops. The steering box mount has been hacked away for clearance on the driver's side.
    HOTRODPRIMER likes this.
  7. "DOES YOUR HOT ROD OR CUSTOM EVER BOTTOM OUT?"
    ...........yes. :confused:
  8. 1971BB427
    1971BB427
    from Oregon
    I have both of my hotrods set up for minimum clearance between rear tires and fenders because I love the look of not having huge gaps above the tires. So I built a mounting bracket, and got urethane bump stops from the local Autozone for $8 a pair and mounted them to stop the axle before the tires can hit the fenders. Pretty easy, and cheap deal to avoid the horrid metal to metal sound.
  9. If it did, I have big problems.
  10. Butch M
    Butch M
    I was always told if they didn't they wasn't low enough
  11. stanlow69
    stanlow69
    Every couple years I have to replace my drain plug on my oil pan. From grinding on the pavement.
  12. My '59 Ford used to bottom out on big bumps with the old leaf springs. Both of my tail pipes have minor flat spots where the axle pinched them on the floor pan. New springs cured that. I was also getting contact with the wheel hop I had on the 1-2 shift, minor on the 2-3 shift. Traction bars were the answer.
  13. Deuces
    Deuces
    from Michigan
    A question you need to ask yourself.... Is it worth it?????...:rolleyes:
  14. HotRod33
    HotRod33
    You mean they are not supposed to bottom out or drag???? I have learned to put in bump stops... After a couple of broken shock mounts....
  15. Dave G in Gansevoort
    from Upstate NY
    It probably will, but look at the bottom of the frame. DSCN1147.JPG DSCN1144.JPG but nothing hangs below the bottom rails
  16. I see where some have problems with the front suspension is bottoming out, I haven't had that problem although I am familuar with tire scrubbing on the front. HRP
    Lil32 likes this.
  17. 48 Indian Rag
    48 Indian Rag
    from conn
    Oh yea, used the cheap way to lower front end torched a couple of coils off, lot of scars on crossmembers finally put new 6 cylinder coils and pair of dropped spindles been about ten years no problems now.
  18. anthony myrick
    anthony myrick
    absolutely
    the inportant atuff is tucked out of the way
    the rest is just sheetmetal and bumpers
    HotRod33 and HOTRODPRIMER like this.
  19. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Basics have not changed from the 1950s tell now really,how good are the roads your driving.?
    Lowered cars looks better then stock hight..........but if your custom or rod gets hung-up coming over the driveway lip coming into the local hot spot cool Drive-Inn=you now look stupid=your lower then 3in. at the center of car. That's what the limit was!!!!!!!!!! for south Florida in most places. Now days some one can blow a lot of $$$$$ for bags and look stuck in the mudd all the time LOL.
    Ture,I think bags are fake low and looks like it ! But I was building customs n rods in the late 50s n early 60s .
    Rickybop, HOTRODPRIMER and Lil32 like this.
  20. Bottoming out on the fronr of any of mu cars was never a problem but I will confess I have owned several 40 Ford DeLuxe coupes & sedans that the lower chins suffered the indignity of the sharp inclines and curbs over the years.
    I also destroyed the front splash apron on my model A pickup driving in the snow, it seems a lowered Model A's front splash apron acts like a snow plow and when it comes in contact with the frozen slush in the middle of the lane the frozen ice wins. HRP
    bchctybob, Lil32 and dana barlow like this.
  21. grdra1
    grdra1
    I recently lowered the rear of my coupe 2.5 inches, when the rear bottomed out the body hit the rear axle severing my brake hose I quickly found out how important a proportional valve is. It worked out ok and now I have new braided brake hoses, stiffened springs and I took to the body with tin snips for extra clearence. Glen 373.JPG 375.JPG
    bchctybob and Lil32 like this.
  22. mrspeedyt
    mrspeedyt
    my cars and trucks have suffered much for being to low for the bad things i’ve encountered. i need to pay more attention obviously. the only old cars that i never had a problem with bottoming out had a non hamb approved suspension. or my stock 23 buick.
  23. WOODEYE
    WOODEYE
    when you drive in Oklahoma and drive on or off a Bridge something will bang !!
    da34guy, Lil32 and Deuces like this.
  24. Rickybop
    Rickybop
    from Michigan
    Drive off the bridge???
    Don't drive off the bridge!
    It wasn't really a custom, but I did have an open exhaust and the rear lowered quite a ways on my 51 Buick Roadmaster. My buddy was good enough to take the torch to the rear springs while I stood back and said... Okay, a little more on the left, okay, a little more on the right...
    I know. LOL
    And it did bottom out sometimes on the bigger bumps. Mostly due to the poor old leaky lever type shocks.
    Not a big problem. Bump.
    Lil32, Deuces and Guy Patterson like this.
  25. Almostdone
    Almostdone
    After 1700 miles I think my rear panhard bar is hitting something - differential case most likely. It’s all a series of adjustments!
    John
    rpm56 and bchctybob like this.
  26. nochop
    nochop
    from norcal
    Yup, added bump a stop. At least it stoped the horrid noise the rear u-joint made when it hit the rear torsion bar.
    Lil32 likes this.
  27. Six Ball
    Six Ball
    from Nevada
    My '53 isn't very low but the last two miles of road to my house is pretty high and in almost close to 50 years of traveling it the road has taken a toll. When the mud is deep the road is even higher. :eek:
    Deuces and Lil32 like this.
  28. stanlow69
    stanlow69
    My car has hydraulics. For 34 years now. I can raise it up 10 inches. It was my daily driver in High School.
    anthony myrick and Deuces like this.
  29. Six Ball
    Six Ball
    from Nevada
    When we built my son's Studebaker around the turn of the century we fitted it with Air Ride. Not so he could drag the frame in town but so he could clear the boulders on the way home.
    That's as low as it gets. :D
    bchctybob and anthony myrick like this.
  30. Chavezk21
    Chavezk21
    My 64 was low. I hardly ever drug unless driveways had a huge amount of pitch. But when it did drag it was usually the mufflers over speed bumps. Midas got to where the didnt want to replace those lifetime guarenteed turbo mufflers on it:eek::Do_O 1964.jpg
    Lil32 likes this.
