Does tube axle take Chevy or Ford spindles
Discussion in 'The Hokey Ass Message Board' started by Phil1934, Aug 1, 2008.
  1. Phil1934
    Phil1934
    I got an old tube axle with my Bantam body, probably FLA Rod Shop. I was told it was for Ford spindles, but I have 1/4" vertical gap between spindle and axle (2" axle boss) and kingpin has 1/32" clearance in axle. Axle had a setscrew instead of locking pin. Spindle does appear to be horizontal on this axle. Do I just need to bush axle and get some shims?
  2. Deuce Roadster
    Deuce Roadster
    There are some axles that were made to use the earlier Chevrolet spindles. I had one years ago under a 32 I bought. It used 53 - 54 Chevrolet car spindles. The axles have a different king-pin angle on them ... and if you adapt the Ford spindles to those axles ... the wheels look like they are way wrong ( top to bottom ) ... to much to straighten by bending the axle :rolleyes:
  3. Phil1934
    Phil1934
    Looks like Ford kingpin is 0.812" and Chevy is 0.867". I guess I'll get a 6" drop
    Ford axle and put this 3" drop Chevy in classifieds.
  4. wheels777
    wheels777
    from York, PA
    I picked up a roadster recently. It has a tubular straight axle the king pin bore is .867. The best I can tell, the king pin angle is 4.1 degrees. Does this match a 53-54 Chevrolet splindle?
  5. Phil1934
    Phil1934
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Generally, when they have the set screw they are for Chevy spindles. I think the year range is 49-54.
    Don
  7. wheels777
    wheels777
    from York, PA
    Don, Yes it has a set screw. Thanks.
    Phil, Great article. Thanks.
    Great news for me, I have a bunch of Chevy axles and brakes for the tubular axle.
