Does anyone know where I can find one of these!??
Discussion in 'The Hokey Ass Message Board' started by BFMC14, Aug 22, 2012.
  1. BFMC14
    BFMC14
    I have looked everywhere...5 different places here locally, all over the internet, with no luck. Its a brass junction block for the brake lines on a 1950 Chevy car, located right under the passenger side door mounted to the frame.
  2. squirrel
    Off another 50 chevy car. You won't find a new one at a local parts store.
  3. Ga55er
    Ga55er
    from Texas
    On my milling machine:D
  4. BFMC14
    BFMC14
    Bob- Its close but that one is for the rear end housing...it might work but I have no way of clamping it down.
    Looks like this is going to turn into the typical headache... seems like the the lines are cut to length specifically for this block, so if I were to find something else that would work I will have to cut and re-flare tubing...
  5. BFMC14
    BFMC14
    If I can't find something, i'll be glad to send it to you Ga55er! The problem is one of the ports got cross threaded and the inverted flare inside the port got creased a bit I believe.
  6. Doctor Detroit
    Doctor Detroit
    I believe those are called "Distribution Blocks". I recently purchased some for my Mercury when I was redoing the brake lines, they were about $20 I think. That key word should help you find them. When I replaced mine, I used a slightly different style than the original, but it worked better. Local auto parts stores will have no idea what you're asking for. The place here in Chicago area that did have them in stock is called Winner's Circle. Maybe their website has some for you to see.
  7. You can always braze a bracket it it, but keep digging on the old car parts sites.
    Tons of links in the site below, also check the truck sources.
    http://www.stovebolt.com/links/parts.html
    Bob
  8. porknbeaner
    porknbeaner
    Carter's in KC if you don't see it on the site you call them, they keep lots of used pieces in stock and GM would have used the same piece on the truck as the car. it costs less to manufacture one piece that serves the same purpose on all models.
    http://www.oldchevytrucks.com/
  9. Doctor Detroit
    Doctor Detroit
  10. BFMC14
    BFMC14
    Thanks Doc! I need that exact one in the pic you posted under the car. I found a few on that website that may work...
  11. liljonny
    liljonny
    from menifee,ca
    What about The Car Shop out here in orange county,ca. They deal with chevy cars and truck from 20's to 80's. Just an ideer.
  12. GMM
    GMM
    from Buhl, ID
    If you cant find one sitting on the local shops shelf, I can build you one. If you have dimensions or you can send it to me and I can build you one of 100. We build manifolds like those all the time, most of the time they are a little more advanced, but it doesn't matter. [​IMG][​IMG]
  13. tommy
    tommy
    unless it is a 100 pts restoration, it should be pretty pretty simple and a lot cheaper to just modify the brake lines some and use a generic brake line tee. Is originality that important under your car? JMHO
  14. 40streetrod
    40streetrod
    from nj
    check out your local HD dealer. they use blocks like that on their bikes. good luck
  15. LSR 2909
    LSR 2909
    from Colorado
    Souns like Ga55er is willing to make you one.
    Sometimes you just gotta' listen!
  16. malibustevens
    malibustevens
    from Illinois
    I think i have one, might not use it, ill look when i get home from work. Gonna be under the 50 all night anyways. Pm me
  17. 40FordGuy
    40FordGuy
    Ditto, find a generic item....The fluid won't mind, if it's run thru a different distribution block. Happy Roddin'
    4TTRUK
  18. Roger Walling
    Roger Walling
  19. Just asking. What is wrong with the one in the picture?
  20. Atwater Mike
    Atwater Mike
    Threads stripped and seat 'scraped'. (from his 3rd post, I believe)
  21. Missed it. Should not be reading while I'm working. Sounds repairable.
  22. Doctor Detroit
    Doctor Detroit
    When I replaced mine, I went with one similar but slightly different. I believe the original piece had two inverted flare fittings and another fitting (compression?) fitting that required a thin copper washer. The replacement piece has three inverted flare fittings. I was redoing my brake lines anyway so it didn't matter. It was a subtle difference I might not have noticed until the guy at the auto parts place pointed it out.
  23. 5window
    5window
    You might have noticed when you put it together the original way and it leaked. More importantly, after all the slamming of parts counter guys, it sounds like you have one who actually knows what he's talking about. That's the treasure here. :)
  24. Ghost of ElMirage
    Ghost of ElMirage
    YUP that's what I was gonna say. Gotta Bridgeport? I will make you one if you send me a print. Priced accordingly
  25. 440 deluxe
    440 deluxe
    call my dad michael (864) 862 -9457 tell him what you need. hes a 49-50 chevy nut!!
  26. Ga55er
    Ga55er
    from Texas
    I can make anything...eventually. Last guy I promised something for is still waiting.:eek: Try to find it or a generic first, save me for last resort. I'm time challenged
  27. Ghost of ElMirage
    Ghost of ElMirage
    Gotcha :D
  28. BFMC14
    BFMC14
    Sorry I haven't replied back guys! Just had my first baby girl a week ago, so its been pretty chaotic around here! I have found a a generic one that I'm going to try from a local Hosing company here (its on order)...the problem is that if its not the exact dimensions as the original I may have to cut and reflare my brake lines in order to fit properly. I know thats possible but I'm trying to avoid all that. I cant really bend the lines to fit either due to a lack of space. Thanks for all of your suggestions and help. I'll see how this one goes and keep you guys posted. Ga55er, thanks for being honest on you being time challenged!
