Does a shock need be mounted fully open??
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Jun 21, 2012.
  1. tlmartin84
    tlmartin84
    from WV
    Should a shock be mounted in the fully open position? Or can it be compressed some at ride height?
    I am getting ready to mount my shocks, and ideally I needed a 14" open and 10" closed shock. Closest thing NAPA has is 16.5-10.25. So will It hurt to compress it a couple inches?
    Also do you all have any pics of custome mounts you have made???
  2. '54Caddy
    '54Caddy
    At ride height, you want the shock to be half compressed
  3. 1/3rd compressed
    An axle will go up further than it will move down under normal conditions.
  4. thunderbirdesq
    thunderbirdesq
    I try to set them up at about 1/3 compressed at ride height.
  5. tlmartin84
    tlmartin84
    from WV
    Thats what I figured, give me 4" up and 2" down....
  6. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Add another vote for 1/3 compressed.
  7. nutajunka
    nutajunka
    from North Indy
    Remember to account for the angle the shock will be mounted in, unless straight up and down.
  8. Pro street rod shocks list IE: ride height 9"
    compressed 7.5"
    Extended 10.5"
    Speedway catalog refferance.
  9. Magnum Wheel Man
    Magnum Wheel Man
    fully extended shocks do ugly things to the ride, when they bottom up, & with the momentum of the body, often get torn apart as well
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you even end up so you are half way between open and closed you will be ok. I use the shocks from Speedway and set them up according to the chart, like dirt t posted.
    Don
