Technical Dodge Truck Steering Box
Discussion in 'Traditional Hot Rods' started by Piewagn, Aug 2, 2019.
  1. Piewagn
    Piewagn
    Anybody ever use one of these earlier Mopar manual steering boxes on their A build?? [​IMG]
  2. goldmountain
    goldmountain
    I'm using one on my T coupe. Don't understand why no one else seems to have latched onto these. They have a Pittman arm that looks like a F-100 and a spline end that will work with practically any steering column and were available up to 1971. The only awkward part is that they take a larger tie rod end than the usual early Ford units but still take 11/16 NF thread. I think it is vastly overlooked.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    Piewagn likes this.
  3. atch
    atch
    Looks like a nice box.
    It looks to me like the rag joint would make these just about universal and make it easier to line up the shaft with the box. And a steering shaft/column like F-100 (early enough to NOT have a key in the column) that came from a floor shift truck would be easy to connect to this and look perfect with a shortened turn signal lever.
    Can we assume that rebuild parts would still be readily available for these? Or were they bulletproof since they came in trucks; therefore probably not needing to be rebuilt?
    Piewagn likes this.
  4. Piewagn
    Piewagn
    I may give this a go....it looks low profile enough to not be in conflict with header. My other route would be the cowl steering set up....
  5. earlymopar
    earlymopar
    The only problem I saw (had) with this box in my Dodge pickup is the number of turns lock to lock which is typical of a truck box (a lot of turns) in order to make turning resistance with a load better. I changed this box out for a Toyota box with fewer turns.
    - EM
    Piewagn likes this.
  6. nobby
    nobby
    hello,
    they are 22 to one ratio
    the helical worm is mopar only to the right - not the same as chevy Saginaw - left
    the pitmann arm points upwards - the other way to a 64 f100 = down
    the sector shaft is too short for a boxed frame
    they can be reversed. - so the 2 bolt holes point rearwards
    they basically have 525 Saginaw internals -although slightly different
    you could fit the input worm from an aluminum mopar box in them for a higher ratio - if you can find one...
    I don't think you can mix these with Saginaw 525 or fords mustang 68 manual boxes, the mesh isn't in the correct place.
    be carefull too as I think the input spline although 5/8 36 is specific to mopar
    they are 1 1/16 out - I think
    so theoretically
    using the core fitted with a 16-1 vette worm, 525 chevy splined sector
    the pitman points down but is still correct - push pull
    you could fit a pre 64 combined shaft find the screw on bearing housing end that takes a column - f-100 does not fit them
    the physical layout is real good for an open frame though
    I have a real good one in bits with the worm reversed if anyone in the uk wants it
    also have a 16-1 vette worm and a 525 splined sector
    oh and a complete c10 4wd manual box
    oh and a couple of rhd 37/8 steering boxes
    oh and a recon 900 series c10/20 4wd box
  7. Piewagn
    Piewagn
    Excellent info!!
  8. goldmountain
    goldmountain
    Don't really know anything about the specs of the box but here is a picture of mine. IMG_1077.JPG
  9. Piewagn
    Piewagn
    What, if any mods did you have to do to fit it inside that rail??
  10. goldmountain
    goldmountain
    Frankie47 likes this.
  11. Piewagn
    Piewagn
