A blast from the past, you read it right. A complete 241 short block stored away in a heated and dry auto body shop since 1969. This was intended to be built as a spare engine for a 1939 Dodge Gasser which will soon be listed here. The block was tanked in the 60s with new cam bearings installed. All the parts included were also purchased in the late 60s. These include but not limited to a new std.std. crank from Storm Engines in NY, new Jahns pistons with all pins/clips and rings 10.5CR, A new set of floated rods balanced by Storm with the crank, all new FM main and rod bearings, full set of Isky adjustable pushrods, Crane Ramsonic Cam assembly ZIP-518 including springs-retainers etc, new Weber 55 lb. steel flywheel. All this plus some used items like pumps and cam gears for $2000. Everything listed is still in the original boxes. We also have at extra cost a block plate, cast standard bell. Because of the weight and bulk this is a local pick-up sale only. Now on Ebay auction.
