Do I need a sender for a ST 602 Sun Tach?
Discussion in 'The Hokey Ass Message Board' started by Tony Travers, Dec 20, 2011.
  1. Tony Travers
    Tony Travers
    Howdy
    I believe this is a ST 602 Sun Tach. Do I need a sender for it? it has 4 wires- red yellow and green in a light brown insulation and a single gray wire.
    Cheers
    Tony
  2. Tony Travers
    Tony Travers
    NO body can help me?
  3. Muttley
    Muttley
    What does the tag on the back of the tach say?
  4. Tony Travers
    Tony Travers
    There is no tag on the out side
  5. phat rat
    phat rat
    Take the tach out of the cup, the terminals will be marked as to where they go. Also on the back it will tell you whether or not you need a transmitter.
  6. richie rebel
    richie rebel
    yes, you need a sending unit the black box,about 3"x6" in size
  7. Larry T
    Larry T
    The only way you're gonna know which tach you have for sure is to take the tach out of the cup. It's no big deal, take the two acorn nuts off and pull it out. The 502 and 602 have about the same face, 502 takes a transmitter, 602 doesn't (I think).
    The tachs that take the transmitter have a positive and a negative wire coming off the tach and a wire going to the light. That's all. The one piece tachs have a power wire, light wire, wire to the coil, and ground wire.
    This is off the top of my head, so take it for what it's worth (not much).
    Larry T
  8. Tony Travers
    Tony Travers
    Thanks to all - I pulled the cup off and it's obvious it doesn't need the box.
    Cheers
    Tony
  9. Shaggy
    Shaggy
    from Sultan, WA
    So anouther related question, on the ones that dont need a sender, are they switchable for 4,6, and 8cyl??
  10. Tony Travers
    Tony Travers
    This one wasn't
