I have a 1964 230 straight six and a 1965 flex plate, starter, and powerglide off of a 283. Will it work?
YES. plain and simple. all sb & BB trannys and flywheel/flex plates bolt up.as long as all are from a inter. bal. motors and Not one peice rear seals. The one peice rear seal cranks have a different crank flange size. You can also go from a 153 to a 168 tooth,as long as the bell housing will let you.Some L6 block were drilled for both type starters.
