DIY Belt grinder attachment for your bench grinder --
Discussion in 'The Hokey Ass Message Board' started by goodfellow, Feb 7, 2014.
  1. goodfellow
    goodfellow
    from Virginia
    Here's how to turn some junk parts into a good 1-1/2 x 30 inch belt grinder attachment for your Craftsman block motor, or similar grinder.
    A few years ago I replaced the timing belt, water pump, and idler pulleys on my Isuzu Rodeo. I kept the pieces in my junk box and this week I decided to make a belt grinder attachment out of them. Any vehicle that has similar timing belt setups can yield these components --
    Here are the pieces that I used for this project -- an idler pulley and a water pump pulley
    I decided to use the water pump pulley as the drive side that attached to the bench grinder shaft. The water pump pulley edges and sides need to be turned flush -- as in the following pic. Other pulleys may not require this, but this one needed to be modified in this manner to fit the bench grinder shaft.
    Here is the water pump pulley temporarily mounted on the grinder using the large OEM washers that came with the grinder to hold the pulley in place. The Craftsman OEM washers are just a bit larger than the pulley and will act as guides for the 1-1/2" x 30" grinding belt
    The old idler pulley is supported by a large bearing and is therefore very steady. This pulley will become the driven grinder wheel. Here I have the machined water pump pulley and the idler pulley mounted to a piece of 1-1/2 angle iron.
    Next I cut another piece of 1-1/2" angle iron to make the adjustable sliding arm that will serve as the body of the attachment as well as the belt tension mechanism.
    The only other big piece that is needed is a belt/tool rest which will allow straight sanding over the top of the sliding arm. This one is fabricated out of 18 ga sheet metal.
    The parts are mocked up to check fit and placement, and I used the three existing 1/4" grinder cover mounting holes on the grinder body to mount the angle iron frame. The frame needed a bit of modification to clear the grinder shaft. I used a 1/2" drill and carbide burr to make the clearance for the shaft.
    Here are the two angle iron pieces with slots down the center to make the belt tension adjustment.
    The final mod was to the machined drive pulley (the former water pump pulley). I bored the hole just larger than the bench grinder shaft to press fit a spare wire wheel bushing into the opening. These bushings come with all new wire wheels and it will make this pulley run nice and true.
    Next, I welded two 1/2 bolts to the bottom of the belt/tool rest so that I could mount it on the frame and also provide adjustment for belt clearance.
    End of Part 1
    Woodsie and VonMoldy like this.
  2. goodfellow
    goodfellow
    from Virginia
    Part 2
    After final mock up, all the components were sanded and painted with Rustoleum Hammered paint and then assembled
    Here is the final assembly --
    The main frame piece is attached to the grinder body
    Then the drive pulley (former water pump pulley) is attached to the shaft.
    Next comes the other half of the frame with the front wheel attached (the old timing belt idler) as well as the belt/tool rest attachment -- this entire assembly will slide back and forth to make belt installs simple and easy
    The belt/tool rest is adjusted to just touch the underside of the moving belt, and then it's locked in place.
    We'll call this job done -- the good thing is that since the rear drive pulley has the large washer lips on each side to guide the belt, there is very little chance of a tracking error on the front pulley -- this thing runs true!
    For less than few dollars in paint, hardware, and a 60 grit 1-1/2 x 30" grinding belt, this grinder attachment works just as well as the commercial $100+ units -- and this one is not made out of cheap stamped steel.
    Hope some of you will try this fix yourself -- a high speed belt grinder is quite handy.
    Good luck!
  3. Mr.Dickies
    Mr.Dickies
    Very impressive fine sir!
  4. oldrelics
    oldrelics
    from Calgary
    Just great, now I have another thing to do on my list:D
  5. oldsjoe
    oldsjoe
    Very good idea and VERY NICE JOB! Now you have a multi tool at your command!
  6. evintho
    evintho
    Pretty darn ingenius! Might have to try that myself.
  7. '54Caddy
    '54Caddy
    Awesome idea! What year Isuzu Rodeo?
  8. impala4speed
    impala4speed
    That is just ingenious. Very impressive work. I love those old block grinders too. Thanks for the great idea.
  9. Toast
    Toast
    from Jenks, OK
    Nice! You going to start mass producing them:D
  10. '51 Norm
    '51 Norm
    from colorado
    I knew that there was a reason that I kept that old bench grinder!
    I have been putting off getting a replacement for the junk HF belt sander for awhile because I didn't want to spend what it cost for a decent one. Now I can have my cake and eat it, too.
  11. TagMan
    TagMan
    Great idea - very ingenious !!
    I love finding another use for parts that might otherwise be tossed.
    I'm not 'green', just cheap !
  12. Neat idea...
    I was thinking of trying something similar, and perhaps using an OEM serpentive belt tensioner/idler on the bottom to tension the sanding belt
    Eric
  13. goodfellow
    goodfellow
    from Virginia
    Sorry for respondoing late: No need for a separate tensioner with this setup. Just loosen the two frame bolts and slide the frame "in" to mount the belt, and then pull the frame back out with some firm hand pressure, and the belt is perfectly tensioned. It doesn't slip at all.
    Good luck!
  14. Brad54
    Brad54
    from Atl Ga
    I've got a Multi-tool belt sander attachment for one of my grinders--it's considerably more expensive than the beauty you just whipped up, so well done for figuring out a way to make it inexpensive!
    It'll be one of the most used tools in your shop. you'll be amazed at how often you use that.
    -Brad
  15. Dave3012
    Dave3012
    Genius idea definitely gonna have a go at this will save $500 + as I live in the U.K and would have to import one , very expensive . A you tube vid would have been awesome aswell . Thanks.
  16. VonMoldy
    VonMoldy
    from UTARRGH!
    I know this is a really old thread but this is pretty ingenious and was wondering how well this belt grinder had worked and if any improvements have been made.
    using idler pulleys was a genius idea and make me wonder is using a tensioner and its pulley to keep tension on the belt is a possibility. I imagine the spring on the tensioner would be way too strong.
  17. Mr48chev
    Thanks for bringing it up, I think I have most of the pieces laying around to put one together.
  18. flatheadpete
    flatheadpete
    from Burton, MI
