Hi all,Can anybody tell me if there is a disk brake kit that will bolt onto 32 ford spindles? or a complete drum kit for the same spindles? thanks Rob
I make a brake kit for them. $90 plus shipping. It includes the bearing adaptors, the caliper mounting plates and bolts. It is "basicly" the same kit everyone offers for the 37-48, but is made to different specs foe the 36 and earlier. You use (and provide) mid 70's rotors (bearings and seals) and metric calipers. No modifications needed, and everything can be found at Checkers or Napa type auto parts stores.
ended up using 41 ford brakes with the conversion kit from speedway. I wilded up the mounting holes, clamped them to the spindles, and drilled new mounting holes. Worked great.
