Disc Brakes-Power Master Cylinder Question
Discussion in 'The Hokey Ass Message Board' started by twochops, Oct 13, 2011.
  1. twochops
    twochops
    Bought the Scarebird kit,for 57 buick used 76 Buick Riviera rotors,
    2002 astro van front calipers, got the 9" booster from Speedway,
    and late Corvette master cylinder. Got everything
    installed, took a test drive, brakes work,but not very good.
    Checked for info on the booster and found it was a Master
    Brake Booster that needs 18" of vacuum which many engines
    do not have. Phat Rat says he thought the 1985 Astro van
    booster would work out good. It looks like it is 8" diameter
    by 6 1/2" deep which I could use. Looking for something not
    quite that deep. Does anyone know of a booster that
    works with a 2 bolt Corvette master cylinder?
    Thanking you for your help
    TwoChops
  2. stealthcruiser
    stealthcruiser
    I'm sure you prolly' know this , but those calipers are known as "low drag" calipers, and take a good volume of fluid to actuate them fully.................Yeech, like an Astro Van master cylinder.
    You did not elaborate on the "not very good part.
  3. twochops
    twochops
    HOPE someone can help on the booster to use.
  4. 53sled
    53sled
    from KCMO
    use all astro parts and you can't miss. newer design is not compatible with 1968 design. get the hydroboost one, they are slick.
  5. twochops
    twochops
    You lost me me with the 68 design,did you mean a 85 vacunn booster
    would not work with the 2002 Astro calipers
  6. Scarebird
    Scarebird
    Alliance Vendor
    from ABQ, USA
    not true. the calipers that do this have a twist in the sealing ring that snaps the piston back a few thousandths, not much to make up with the master. The 1985-87 "BK" S10 Tahoe booster is a cherry piece - my pontiac draws 11 inHg at idle and this booster stops quite well. It will also accept your vette master with the right pushrod.
  7. fordor41
    fordor41
    I have MP M/C & booster. I believe it is a corvette M/C and a dual 7" booster.
  8. stealthcruiser
    stealthcruiser
    Thanks, I stand corrected............................I was thinking about 2 earlier Astro's that I owned, and I was told that was what they were, and the more volume deal..............................Which could be B/S as well.:eek:
