Hello fellow HAMBer's. Wondering if anyone knows where I can get a disc brake conversion kit for my 62 Lincoln continental.
Don't know of a swap but '65/'69 had K-H Discs but you need the matching wheels to clear the calipers. The swap will depend if the Ball joints and Tie rods use the same taper size. Later single piston setups will work to again based on the same criteria. I don't know what the spindle geometry issues may be so caveat emptor.
Porter Man, Front and rear kits for your '62 Lincoln are available at www.gearheadengineer.com . Full disclosure: I designed and make these kits. My contact information is on the web site. - John
