Projects Difference between 51 and 55 Ford rear end
Discussion in 'The Hokey Ass Message Board' started by scotts52, Feb 1, 2019.
  1. scotts52
    scotts52
    If my research is correct, it looks like the 51 and 55 Ford rear end is the same. I'm looking at passenger cars. So, my question is, can they interchange or are there other differences that would be a problem?
  2. Mr48chev
    I don't think there are any major differences between 51 and 56 unless the location of the spring pads changed.
    Rock Auto does show three different cover gaskets for those years though so there may be some differences.
    scotts52 likes this.
  3. dwollam
    dwollam
    I do know that '54 center section will bolt in a '51 housing but you have to use the '54 axles, they are finer splined, which is a good thing! I have a '56 rearend, I will have to compare it to one of my '51's.
    Dave
  4. I believe there was some bearing upgrades also. They'll swap as a complete unit, but you can't randomly mix the internal parts. With the additional power of the new OHV V8s, Ford beefed up the rear axle.
  5. bdynpnt
    bdynpnt
    49-56 are all the same ,I had a 49 coupe in high school put a 56 rear with a posi under it.
    Sent from my SM-G965U using The H.A.M.B. mobile app
  6. Ford offered a posi in a 56 passenger car rearend?
  7. bdynpnt
    bdynpnt
    It was an aftermarket gear set and carrier guy had a hot rod Victoria and rolled it bought it and traction bars cheap
    56don likes this.
  8. bdynpnt
    bdynpnt
    That was in 70
  9. The real difference is 4 years. :rolleyes:
    The rear from a '55 farilane is probably not a direct bolt in to a '51 Business coupe. But I could be mistaken. LOL
  10. bdynpnt
    bdynpnt
    The 56 bolted into my 49
  11. well there ya go. ;)
  12. Should be Dana 44 rear in 49'-56'
  13. bdynpnt
    bdynpnt
    The dana 44 was in wagons , t birds and couriers , the cars used a Hotchkiss with drop out center section.the trucks also used the dana but back then they were spicer
