Technical Desoto brake set up
Discussion in 'The Hokey Ass Message Board' started by chewie1, Apr 22, 2017.
  1. chewie1
    chewie1
    Hi folks
    I'm having trouble getting my brakes set up on my 47desoto
    I do not have access to the special tool
    Being as I'm In England even the old boys in the old garage locally do not have any ideas
    Is there a trick to setting the brakes without the tool?
    Thanks in advance
  2. post-81542-0-45062100-1450459671.jpg Try this device.... post-81542-0-47328400-1450459679.jpg
  3. ,,,that deal is helpful, but, not a foolproof fix,,, Park,,'53 DeSoto
    Flat Six Fix likes this.
  4. Nothing is foolproof like the original tool.
  5. chewie1
    chewie1
    Helpful has got to be better than stabing in the dark!
    Or pumping the brakes evertime you need to stop
    Thanks 31 dodger I'll give it a go as soon as I get time
    Sent from my E2105 using The H.A.M.B. mobile app
  6. Flat Six Fix
    Flat Six Fix
    I have done them both with the tool and without.
    These brake shoes when relined or new, and drums surfaced, now face another dilemma arcing the shoe to the drum , with a drum arcing machine. This gives instant great brakes, usually.
    Or you can go by feel, drive the car, let shoes wear in and seat and minor adjust them periodically.
    Get a "service manual" and read about th methods to achieve this.
    go here for more info, help and details... www.p15-d24.com
    31Dodger likes this.
  7. First and foremost, ADJUST prior to bleeding the brakes. Otherwise, you will never get a pedal.
  8. chewie1
    chewie1
  9. Flat Six Fix
    Flat Six Fix
    Adjust those brakes, and you want to feel a slight drag, all of this and re bleed brakes if the pedal pumping has to be done for hgh pedal.
    Start with the major adjustment, the shoe anchor adjusters, adjust on each drum until a slight drag, then adjust the minor adjuster, slightly, if the drums starts to spin without drag, go and slightly adjust the major adjusters, then back to the minor adjusters for a final tweak.
    They are both cam concentric, so they go up and own and or in and out as they turn a full revolution.
    Or do what I have done in the past, on the major adjusters, point the arrows on the rear drums toward each other, then adjust the minor adjuster till drums are dragging, on the front point each anchor arrow pointing out from the shoe they anchor, then do a minor adjustment till brakes drag, pump the brakes and see if they still have a drag at each wheel(s).
    Then drive for a few hundred miles, and do a minor adjustment, they will wear in and seat, then you should have real nice brakes, those are a 11 inch brakes, with dual cyls up front, they stop pretty damn good..
  10. Rusty O'Toole
    Rusty O'Toole
    If you want really good brakes start by contouring the linings to fit the drum. You will have to take the shoes off, put them in the drum and sand off the lining where they touch until they touch the full length of the shoe. Brake shops used to have a machine to do this but that was a long time ago.
    Then with the shoes on the backing plate you have to adjust them until they fit in the drums exactly but with .010 clearance. That is the reason they had the special adjusting tool, or home made equivalent.
    I have thought of drilling a small hole in the drum and using a wire feeler gauge.
    j hansen likes this.
  11. Flat Six Fix
    Flat Six Fix
    Rusty what you are stating is what i said, and its the correct way for great brakes immediately, we still have a shop or 2 that can arc shoes, so maybe England might too.
    I have done it my way, with no .010 precise clearance, and brakes were fine, they will need to wear in and seat, if they have not been arced to fit...
  12. NielsK
    NielsK
    from Denmark
    I've done what Rusty suggested on my Plymouth 30 U. I drilled a 10 mm hole in each drum and used a piece of wire as gauge
    Sent from my SM-G930F using The H.A.M.B. mobile app
  13. chewie1
    chewie1
    Nielsk:
    I'm presuming you drill the hole on the edge of the drum
    This way seems to be the easiest solution
  14. NielsK
    NielsK
    from Denmark
    Yeah exactly. Picked the idea up from an old mechanic. He told me they always did it like this
    chewie1 likes this.
  15. chewie1
    chewie1
    Great I'll be getting the drill out this week
  16. NielsK
    NielsK
    from Denmark
