Does anyone know where I can get an adapter plate and a flywheel for a 1949 desoto . I've been looking everywhere but no luck . Also I'm planning on changing my transmission to an automatic.
What trans are you wanting to use? Understand that your current configuration relies on rear mounts attached to the trans/bell and all of that will be lost with a modern trans swap so be prepared to do some fabrication work to have proper mounts.....you really cannot expect to use the mount under the trans as a replacement. .
