Technical ***December 2018 Banger Meet - What Will Santa Bring***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2018.
  1. I always like to post a photo when I check in! This is one shot by Tam McPartland at the famous "Corkscrew at Laguna Seca Raceway last August!
  2. Shutter Speed
    Shutter Speed
    Your coupe uses a lot of oil!
    jerseyboy and winduptoy like this.
  3. utahdodge
    utahdodge
    It's no wonder they put it out to pasture right? ;)
    chryslerfan55 and Shutter Speed like this.
  4. Howdy Everyone! Had a quick question, I’m thinking of selling my three bolt head/water pump setup as I want to go to a 4bolt Head. What would something like this go for? (Just head and water pump)
    Jet96 and chryslerfan55 like this.
  5. Dustyp489
    Dustyp489
    Checking in, made work list for this winter
    Retson the Racer likes this.
  6. surf10
    surf10
    checking in, tubs back together now time to start putting things back on the chassis
  7. wheeltramp brian
    wheeltramp brian
    Hey retson,what the compression ratio on the head? I might be interested in it.
  8. It’s 4.6, same as the stock B head. I’m sure you can shave off a few thousandths to bump it up. Not asking too much for it
  9. walls
    walls
    D6E04F56-2E15-46DF-A343-0E1D971A62A2.jpeg Anyone have an aluminum Thomas head to compare this to?
    Just wondering if they have the same combustion chamber.
    This is a cast iron Thomas, I was told 7:1
    Wasn’t really looking for one but when it was available I had to take it.
    Dannerr and chryslerfan55 like this.
  10. 12secvx
    12secvx
    513FF5FE-607E-4F33-B077-44611AE3436E.jpeg 432A7B5E-90CA-4C55-8B04-3F61B6DF8C18.jpeg
    It look similar to my repop Thomas aluminum head. Which is advertised at 6.7 compression.
  11. lake_harley
    lake_harley
    It might be old info for many here, but at the bottom of the pages in this link is a chart that translates head volume in CC's to approximate compression ratio. http://www.fordgarage.com/pages/headcompressionratio.htm
    I could see it being helpful if you have an "unknown" CR head.
    Lynn
    Dannerr, chryslerfan55 and Jiminy like this.
  12. RussTee
    RussTee
    Anyone want to post what main jets and power valves they are useing in their twin 97s near sea level?
  13. two coupes
    two coupes
    IMG_3047.JPG I live about 100 ft over sealevel and I use 43 as main jets and smallest available powervalves on my 214 cui 4-banger, tuned it in with a wideband lambda and got it close to perfect, a little to the rich side.
    Jet96, Shutter Speed, Dannerr and 6 others like this.
  14. RussTee
    RussTee
    Thank you two coupes this is the type of information I need yes I have seen the theory but this is what is actually used a good starting point when you have to get parts from another country
  15. kweb1936
    kweb1936
    from salem il.
    [​IMG] just checking in
    Jet96, Shutter Speed, burl and 5 others like this.
  16. I guess since I am Santa at my house, I can say Santa brought me some cool wheels.... Wonder if dropping the front 4" will fit in my stocking...... IMG_0666.jpg
  17. Six Ball
    Six Ball
    from Nevada
    The trans is a side loader and appears to be a Borg Warner T-85 OD. The OD should be an R-11. If all that is true you could not possibly hurt it with anything a good strong B-Banger will do. You'll break the crank, drive shaft, U-joints, rear gears, axles, and shear the hub keys before the trans knows there was a problem.
  18. Six Ball
    Six Ball
    from Nevada
    What will Santa Bring? Elves to put this thing together?
  19. Kewl65
    Kewl65
    Build thread?
  20. Howdy everyone, parts to install this Model B Distributor are coming in, does someone mind taking a picture of their wiring setup? I have a universal key ignition, but don't understand the wiring for it all. thanks
  21. Anyone know what these numbers in the block are?? It's a B block.
  22. Crazydaddyo
    Crazydaddyo
    chryslerfan55, GuyW, Jet96 and 2 others like this.
  23. OOHH thats bad, very bad.
    I'll take it off your hands to ease your pain.............ship it to me.
    J
  24. Seriously though. I have three B blocks and none of them have a number cast into the side. This one does. I know it is a diamond block so may be a later model.
  25. Crazydaddyo
    Crazydaddyo
    My understanding is that on Diamond blocks, those numbers are the month and year the casting was cast. 2 = Feb 38 = 1938
    Jiminy likes this.
  26. chryslerfan55 likes this.
  27. JT1930
    JT1930
    7C017DE5-8543-4509-B6AF-DB8556E2BF8B.jpeg Merry Christmas ya filthy animals.
    Picked up our tree in town.
  28. winduptoy
    winduptoy
    JPEG_20180826_194604_-441503843.jpg IMG_20181221_161843940_HDR.jpg IMG_20181221_161855786_HDR.jpg
    I did get it fired up in November but you know how that goes....a little more time on it and drove it out of the garage and up and down the drive. Have some tuning to do but it is healthy. I'm going to like the T-5..
    Sent from my XT1254 using The H.A.M.B. mobile app
  29. Binger
    Binger
    from wyoming
    That is awesome Larry!!! The T-5 made my coupe a ton more fun to drive! Merry Christmas to you and Judy!
