Technical De code my Dodge Red Ram engine
Discussion in 'Traditional Hot Rods' started by jcb50, May 14, 2020.
  1. jcb50
    jcb50
    I purchased a Dodge Red Ram hemi as a 315
    It has BT344 stamped on top of block in front of the valley cover.
    I understood it should have D632 for 2 barrel 315.
    Can anyone please explain?
    Thanks JCB
  2. Hnstray
    Hnstray
    from Quincy, IL
    I am looking in Leo Lindquist’s Bible of MOPAR Hemi/Poly engines and cannot find your specific code. The closest code is VT344 and that is listed as a either a 241 Hemi or 259 Poly. The vast majority of truck engine codes begin with VT .....there are no BT prefixes in the truck codes shown. I am going to post a pic of that page here in a few minutes.
    E27E1F7C-9F85-420E-9EAA-8EE96E2BD39B.jpeg 6B3D9051-92B7-4BC6-9727-8CF8D083C2E4.jpeg A26CD957-5B4F-4716-9101-32501268281C.jpeg
    Hope this helps.....
    Ray
  3. Hnstray
    Hnstray
    from Quincy, IL
    More info that may be useful to you......
    8CFA0BFB-D4B3-47ED-8307-2581C7E8475B.jpeg 27E3707D-40DC-4828-BD04-C13EC6A03491.jpeg B305D6A0-C854-4F7D-B549-0F617734B85A.jpeg
  4. treb11
    treb11
    Excellent information Hnstray! B and V are next to each other on the keyboard. Just sayin'
    loudbang and Beanscoot like this.
  5. 73RR
    73RR
    As shown in the book, MaMopar used the same ID code for more than one application so the only way to be sure is to measure the bore before ordering parts.
    loudbang and kidcampbell71 like this.
  6. jcb50
    jcb50
    Thanks for the info. Appreciate your effort. I guess the only way is pull the pan and check.
    All very confusing. When I pull the pan, i will report back. Regards JCB
    loudbang and Hnstray like this.
  7. sunbeam
    sunbeam
    Does the engine have side mounts? only tall decks had them with exception of 270 1956 poly. Another point low deck motors did not have harmonic balancers except for some trucks.
  8. One - it shouldn't say Red Ram or Super Red Ram on the valve covers if it is a 315 block. Show a picture of the # above the water pump on the drivers side. Sounds like you have a truck motor and not sure what pulling the pan will help. Pictures help us.......
  9. Good point - the 270 motor did have side mounts also........what I'm using for my hurt 315.
  10. jcb50
    jcb50
    Thanks guys. Will have a look tonight when I get home and take some pictures to post, much appreciated
    JCB
  11. jcb50
    jcb50
    Please see photos attached.
    Desoto291Hemi likes this.
  12. sunbeam
    sunbeam
    my moneys on a 315
  13. Isn’t that designation D344 ?
    Tommy
  14. Ebbsspeed
    Ebbsspeed
    Does that "R" stamped in front of the number mean "Replacement"?
  15. jcb50
    jcb50
    Thanks guys
    So I believe the consensus is that it is a 315.
    I can now look into adapting it to my Lasalle trans.
    Cheers
  16. 270dodge
    270dodge
    from Ohio
    Pull the pan and measure a rod journal.
    241-270 1.937
    315 2.25
    End of mystery.
    All Hemi's- poly's except the 51- 53 extended bell engine use the same adapter.
  17. George
    George
    Should have said 51-53 Chrysler, maybe some 54s also......
  18. sunbeam
    sunbeam
    Because of the difference in deck height the tall deck intake is wider the center to center of the front two bolt holes on a low deck is 8 1/2 inches a tall deck will be wider I don't have one to measure right now.
  19. jcb50
    jcb50
  20. jcb50
    jcb50
    Thanks. mine is approx 10, so obviously the high deck.
    Simple answer, Appreciate.
  21. Looks like dimple valve covers and a truck water pump....good score if it's a 315.
  22. wstory
    wstory
    from So Calif
    I'm a little late to the conversation about your engine size. For what it's worth, my 270 does NOT have side motor mounts.
  23. sunbeam
    sunbeam
    Side mounts 270s were 1956 and I think they were only polys.
    Hnstray and George like this.
  24. George
    George
    correct
