Looking for some ideas for a custom fuel rail/ log setup for my 303. Sent from my iPhone using H.A.M.B.
It looks like you're running a progressive linkage? Rather than use flexible fuel hose on my 6x2 X1, I use a 6-port Eelco fuel log in conjunction with hard line and compression fittings at carbs and fuel log.
Thanks I was thinking of making a rail similar to that to match my finned valve covers and valley cover. Sent from my iPhone using H.A.M.B.
This is what I used - https://www.summitracing.com/parts/aei-14107 Probably wouldn't be too hard to make your own if you knew what you were doing, which I don't.
I used a Moon fuel block that I mounted to the carb adapter, formed the hard lines myself with compression fittings at the fuel block and chrome Stromberg fittings on the inlets, then polished to nice luster. Progressive linkage, center carb choke, braided Russell line to the firewall mounted fuel filter. Quick release 2 way valved fuel fitting at the fuel block to allow for easy removal of blower/carbs/motor if (when) necessary
It is wicked expensive! I think I got it at Summit Racing. I may have some left over, if you like I'll check tonight. Thanks for the compliment too. I took her in to the tune up shop today, running real rich and fouling plugs. Hopefully by tomorrow the flatty will run as good as good as she looks.
Those flatties are a work of art. I picked up 2 of them a few years ago. Can’t wait to tear into them. Sent from my iPhone using H.A.M.B.
