Hot Rods Custom made rims
Discussion in 'The Hokey Ass Message Board' started by 3Deuce40, Feb 2, 2018.
  1. 3Deuce40
    3Deuce40
    from Colorado
    Does anybody know of a place that will make custom made rims? Wheel Vintiques and Wheel Smith don't have the offset or size I am looking for. Not sure who else would do something like that. Any help is appreciated
  2. nochop
    nochop
    from norcal
  3. zzford
    zzford
    Rims or wheels?
  4. 3Deuce40
    3Deuce40
    from Colorado
    Rims. Needing a 16x5 (1.875 backspace)
  5. Wheel vintiques will weld up any offset you need. Had to return a pair of smoothies a couple of years ago to have the offset changed, wasn't expensive- quick turnaround.
    Tim likes this.
  6. gimpyshotrods
    gimpyshotrods
    So, you want the whole wheel, not just the rim?
  7. 3Deuce40
    3Deuce40
    from Colorado
  8. 3Deuce40
    3Deuce40
    from Colorado
    I talked to them at the GNRS and they sure didn’t mention that
  9. gimpyshotrods
    gimpyshotrods
  10. 3Deuce40
    3Deuce40
    from Colorado
  11. I don't understand why most of us will hand build a chassis for our Cars but are afraid to weld on a steel wheel, not that you are. If you happen to have a 16 X 6 rim why not just take 1" out of it?
    The Wizzard
  12. gimpyshotrods
    gimpyshotrods
    What size tire are you planning on running?
  13. 3Deuce40
    3Deuce40
    from Colorado
    I have 16x5's now and the tire is tucked in close to the car. I don't have a lot of room so I need to stay with that size. I built the car around that Rocket wheel and tucked them close. If the car leans to one side, I thing the tire will rub
  14. alchemy
    alchemy
    Buy a good quality wheel spacer/adapter, put it on to check your clearances, and I bet you can forget it's even there.
    3Deuce40 likes this.
  15. gimpyshotrods
    gimpyshotrods
    I am confused (or you are).
    You say that you want a 16" x 5" wheel with a 1.875" backsapce.
    You say that that wheel keeps the tire tucked into the car.
    A wheel with a 1.875" backspace would be pushed out about as far as that wheel could be, and still be welded-up.
    Are you sure that you are not confusing backspacing with offset? Offset is measured in relationship to the wheel center line.
    A 16" x 5" wheel, with a +1.875" offset would have a 3.875" backspacing.
    Which exact 16" x 5" Rocket wheels are on it?
    j-jock likes this.
  16. 3Deuce40
    3Deuce40
    from Colorado
    Ok, my mistake. I'm looking for a 16x5 with a 1.875 backspace. I'm running the "as cast" wheel. Sorry. This stuff makes my brain hurt.
  17. 3Deuce40
    3Deuce40
    from Colorado
    I'm looking to run a ring and a cap versus the Rocket "smoothie" wheel I have now
  18. gimpyshotrods
    gimpyshotrods
    So these?
  19. 3Deuce40
    3Deuce40
    from Colorado
    Correct. That's what I am running now with a 750/16
  20. gimpyshotrods
    gimpyshotrods
    On the FRONT?!
  21. 3Deuce40
    3Deuce40
    from Colorado
    Rear. Fronts are 500/16. Same 16x5 wheel
  22. gimpyshotrods
    gimpyshotrods
    That will in not pushed IN, as you described. It is pushed OUT.
    Unless you have a fender to contend with, you can run any 16" x 5" wheel you want, and put a good quality spacer under it, to push that wheel out to the desired spacing.
  23. 3Deuce40
    3Deuce40
    from Colorado
    I cant seem to find a 16x5 in a steel wheel. Could I run a spacer and then run a 16x6???
  24. gimpyshotrods
    gimpyshotrods
    A typical 16" x 6" Wheel Vintiques #12 smoothie wheel has a 4" backspacing.
    If you want a 1.875" (or 1-7/8") backspacing, you would need a 2-1/8" spacer.
    Unless you are going to hit a fender, you can round-up the spacer thickness, to the next size that is commonly for sale.
    i.rant likes this.
  25. gimpyshotrods
    gimpyshotrods
    What is your wheel bolt pattern?
    A 6" wheel will move the beads out a 1/2" wider on each side. This will mean that the tire will overhang the wheel lip a little less. So much so that you will likely be able to use a common 2" spacer. The reduction in overhang will make up for the 1/8" difference in backspacing.
    i.rant likes this.
  26. 3Deuce40
    3Deuce40
    from Colorado
    5 on 4/12
  27. 3Deuce40
    3Deuce40
    from Colorado
    Wheel Smith can do a 2.00 backspace. That might work
  28. 3Deuce40
    3Deuce40
    from Colorado
    Dude. Youre the man. I appreciate the help!! Thanks
  29. gimpyshotrods
    gimpyshotrods
    I would probably move to a 16" x 6" on that tire, for the overhang reason that I mentioned above. Not only does that make a little more clearance, it will make the tire more stable in corners, and at a lower, more comfortable operating pressure.
  30. ROADSTER1927
    ROADSTER1927
    If you want to have more clearance to the inside, just space out the wheels you have.
