custom HF bead roller dies... interest?
Discussion in 'The Hokey Ass Message Board' started by FiddyFour, Apr 12, 2011.
  1. FiddyFour
    FiddyFour
    i now have Delrin (tm) die sets available!
  2. Inland empire hot rods
    from so cal
    marking for further review
  3. willymakeit
    willymakeit
    Subscribed. I'm going to buy some dies.
  4. rockable
    rockable
    Got my steel dies from Fiddy today. They look great and the one piece of scrap I ran through my roller worked great. Thanks, Fiddy!
  5. I got a set of the steel dies as well they were nicely finished and Fiddy was a pleasure to deal with. Rob
  6. Johnnydmetal
    Johnnydmetal
    Hello,
    First timer here but was drawn in by the prospect of the custom dies for the HF roller.
    I need to produce a 90 deg flange on one end of a 3" diameter welded seam mild steel tube 5 1/2" long with a 16ga (0.065) wall. The finished flare should be about a 1/4" to 3/8".
    I'm adding a bracket to the non shaft side to beef up the strength and shorten the throat to handle the stress of rolling the 16ga material.
    My Question to you is can I form the flat flange with a tipping die or do I need a die specifically for flaring?
    How much is a set of your tipping dies?
    If the special die is Required can you make me a set and How much $ is it?
    Thanks
    John
  7. rockable
    rockable
    You may can start it with a tipping die but at some point, you're going to have to do some serious stretching of the outside of that flange. It's not going to be easy, IMO. I think I would make two pieces and weld them up.
  8. rockable
    rockable
    Another way would be to break the flange on the flat sheet 16 ga and then use a stretcher on the flange to make it round. You'd have to find a piece of pipe or something to help you form the tube as you go, then weld up the seam. 3" is going to be tough, IMO.
  9. HRK-hotrods
    HRK-hotrods
    How are the beltline dies working? I'm thinking of having you make a set for my Chevy roadster.
  10. FiddyFour
    FiddyFour
    Price is $75 shipped insured in the USA, pm for Canadian and overseas shipping quote
    PM me about the pipe flange... might be better to make it from two pieces as was mentioned
    Shoot me a PM... I'll need a good piece of belt line steel to work with
  11. txturbo
    txturbo
    anyone know if the HF dies will fit a Woodward Fab roller?
  12. x2 that thanks
  13. FiddyFour
    FiddyFour
    i believe they do... so long as the end of the shafts measures 7/8" and the center to center measurement is 2" my dies will work on your roller
  14. txturbo
    txturbo
    Ok...thanks....I'll have measure when I get home.
  15. HRK-hotrods
    HRK-hotrods
    Ok, I'll pm you for more details. I will see if I can make a profile piece rather than cutting my door.
  16. Irrational Metalworks
    Alliance Vendor
    from DFW
    You don't have to cut a piece of your door apart! If you want a perfect profile,make a mold out of bondo.then you can slice a piece off and transfer the profile.
  17. truckjim
    truckjim
    Ok! Guess its time to get a HF bead roller. Never trusted their dies so used a buddies no name setup. Tipping and louver dies please! :)
  18. FiddyFour
    FiddyFour
    PM me on the tipping dies... as of right now i have no plans on making louver dies, sorry :(
  19. Dave Williams makes louver dies.
    Steve
  20. 5150Pontiac
    5150Pontiac
    Are you still taking orders for tipping dies?
  21. 5150Pontiac
    5150Pontiac
    I'll take a set!
  22. FiddyFour
    FiddyFour
    i will be making another run of dies that will be ready to ship at the end of april/early may
  23. FriedaB
    FriedaB
    These are beautiful, and are you still making the dies? It's been 2 years since the last post. If so how much and can I get a set of the second kind. We are stupidly or not as your mind may guess , making a car with an aluminum body and need to roll the edge around the driver and passenger? Oh please still be making these!!!!
  24. FiddyFour
    FiddyFour
    yes, i am still making the dies, both delrin and steel. will be running a batch at the end of this month
  25. FriedaB
    FriedaB
    Will they fit my current bead roller or do I need a different appliance to use them???
  26. FriedaB
    FriedaB
    I had to check, I do need steel, these will be for the Aluminum body of the car we are attempting to build. Thank you so much.
  27. FiddyFour
    FiddyFour
    if you own the harbor freight beat roller, these are made specifically for it
  28. FriedaB
    FriedaB
    I think that is exactly the bead roller we currently have. It works with all the dies he had and all the ones that came with it, best of both worlds. :)
  29. FriedaB
    FriedaB
    How much do you need and how/where should I send the funds. The buck is just about finished and then he ready to start cutting out the body panels to shape each with the stuff. If he has a good idea when they will ship he will be easier to work with.
  30. craigibc
    craigibc
    Will these fit the Woodard Fab roller?
Links on The Garage Journal are affiliated by SOVRN.
