Technical Custom guys- sexiest hubcaps ever?
Discussion in 'Traditional Customs' started by Roothawg, Aug 9, 2018.
  1. dave 62 pb
    dave 62 pb
  2. dave 62 pb
    dave 62 pb
    Got these 58 Edsel caps over here in the UK , they were drilled for spinners but they were missing and rare over here so had to fill the holes with something then found these mini rockets that work in well with the 50s theme
  3. 51 mercules
    51 mercules
    Like the idea. Might give that a try. Mine were originally painted in the 50's and I want to reproduce that look. [​IMG][​IMG]
  4. Rand Man
    Rand Man
    It’s something like a 51 Desoto, that I put a bullet cone on. D88C8FC2-D94B-409C-9054-DE33B1578A9A.jpeg
  5. I'm not one to toot my own horn, but I thought I'd share a picture of the 'caps on my non-HAMB friendly Merc.
    I added an accessory bullet and a few drawer pulls to some old Plymouth Satellites. Must have been an ok idea, as the KKOA powers that be said they were the "Most Spectacular Hubcaps" at the 40th. An unexpected surprise that I never saw coming. It was just the cherry on top of a "Spectacular" weekend! E
    my caps.jpe
  6. 50 Merc Man
    50 Merc Man
  7. 50 Merc Man
    50 Merc Man
    Can’t go wrong with Oldsmobile fiestas
    TagMan likes this.
  8. Squeak Bell
    Squeak Bell
    I made these out of mid '50's Packard full wheel covers and grafted in a '40 Ford Standard 'skin'......more rings than URANUS...!!! Cheers,Squeak.
    ElmCityGeoff, bob-o, Dan Hay and 4 others like this.
  9. kustomclassics
    kustomclassics
  10. Jacksmith
    Jacksmith
    from Aridzona
    They are definitely vibrators!
    mikhett likes this.
  11. 54delray
    54delray
    from Fremont NE
    Kustom Khrysler
    BigRRR, Chris Nantus, Sancho and 4 others like this.
  12. 57JoeFoMoPar
    57JoeFoMoPar
    There are many great options. The problem with some of them is getting them in a 15" size, which IMHO is the only proper wheel side on a 1950's era car, unless you're running Astros
    mikhett, OG lil E and Sancho like this.
  13. 54delray
    54delray
    from Fremont NE
    Agreed. I am in the 15" only camp. I know that a few brands went to 14" in the late 50's. If I ever had one, I'd get a set of 15's to be able to run some cool covers.
  14. 50Fraud
    50Fraud
    I'll nominate these. They're '56 Chrysler accessory spinners. They are generally similar to other spinners of the mid-'50s, like Fiestas and Lancers, but they are vastly less common. I've never seen another set used on a custom:
  15. 54delray
    54delray
    from Fremont NE
    Those are magnificent! I see them on that online auction site, which is where I grabbed these pics. A combination of Kool, pricey and rare. Were they only for a specific model, like a LeBaron, or could you get them added (at the dealership) to a regular '56 New Yorker?
    They appear to be based off of the more common stainless wheel cover with a pot-metal, one-piece, 3-blade spinner bolted to it. I guess I can't see from the pics if the blades are cast separate or as part of the center.
  16. 50Fraud
    50Fraud
    I've seen them advertised with one of the Chrysler model names attached (like New Yorker or Windsor), but I don't know if they were exclusive to that model. I have seen them with two different center designs -- my 4 have the same red centers as shown in your 2nd picture, and I have a single with the same design as your 3rd picture, but with a more colorful paint deco.
    You are correct that they are basically the same stainless cover as your 3rd picture. Although they look similar to the 1st generation Lancers, they are a completely different stamping. The die-cast spinner is a single piece, with the blades cast integrally with the center cone. The spinners are among the worst die-castings I've ever seen, with reference to the horrible pitting. I had one good chrome shop refuse to take them because of the pitting. I ended up sending them to a midwest shop who did an excellent job, but at a huge cost. As I recall, it was something like $700 to have 5 parts plated. I have over $1000 in the full set of 4; I doubt that I would do it again.
    OG lil E, Sancho and 54delray like this.
  17. 54delray
    54delray
    from Fremont NE
    Thanks so much for the detailed info on these. I learned something new.
    I've got several of the 1st generation Lancers and they too have the pitting problem on the pot metal centers.
    That might just be worth the grand you got in them ... or maybe just priceless!!!
  18. ezrodder1
    ezrodder1
    1. 1952-59 Ford Social Group
    I don’t know the manufacturer of these. Found them at a swap meet. Running them on my 53 customline in my avitar.
  19. Clydesdale
    Clydesdale
    Picked up these Lincoln Capri covers the other week.
    Rough ones will go out back behind the skirts, fronts will get the nice ones but with a bullet in the centre as they wont fit over the drum snout right now.
    Gambler 1962 and 54delray like this.
  20. 54delray
    54delray
    from Fremont NE
    Like this? Cool choice but I'm not sure if the bullet will solve your clearance issue.
    DSCN6014.JPG This is a medium size bullet but they all attach the same way. Drill out a small hole in the center for the bolt. It has to stick through enough to put a washer/nut on, which will actually reduce the clearance of the dust cap
  21. Clydesdale
    Clydesdale
    Yea that's my plan, I had already thought of a solution to the mounting problem, I'll gut the inside of the bullet, panel bond a strap inside that follows the inside contour down to a 90° bend with captive nuts ;)
    Cool to see my idea in real life though, thankyou sir
  22. 54delray
    54delray
    from Fremont NE
    Love it. Custom car guys and hot rodders will always find a solution to look cool or go fast!! HAMB on!
  23. 58prostreet
    58prostreet
    I had same problem on some 56 Imperial caps . I sectioned the dust cap about 1/4in. and it clears
    OG lil E, 54delray and Clydesdale like this.
  24. fourspd2quad
    fourspd2quad
    It looks like a statue that identifies as a hubcap.:confused:
  25. Sanford&Son
    Sanford&Son
    from Visalia,Ca
    I have always liked the Stude Caps, I have a nice set available. (pm me if interested)
  26. millersgarage
    millersgarage
    Roothawg likes this.
  27. 50 Merc Man
    50 Merc Man
  28. 1low52
    1low52
  29. I picked these up this summer. I think they’re Oldsmobile (?). I like them.
  30. Rarefish383S
    Rarefish383S
    I had a 64 Riviera, that was a factory 425 2-4 barrel car. It had Finned Aluminum hub caps with spinners in the center. Only problem was, the hub caps bolted to the wheel. The spinners popped off to expose the lugs. The people that had the car before me, never told the gas station that the hub caps bolted to the wheel. They always put the rookie on tires, and they popped chunks of the aluminum rim out, trying to pry them off. Looking for pics?
