Custom Grills
Discussion in 'The Hokey Ass Message Board' started by 48flthdf1, Mar 2, 2012.
  1. 48flthdf1
    48flthdf1
    Someone I am sure has asked the question...What kinda of ideas do you have for a custom grill? I want to build a custom grill for my 1953 customline ford. Trying to figure out if I should go with stainless or billet...Or even steel and paint it black...Any Ideas would be of help...Thanks, Scot
  2. williebill
    williebill
    steel
    weld
    chrome
  3. eaglebeak
    eaglebeak
    First...you need a design.
  4. Mike Rotch
    Mike Rotch
    from Easley SC
    Needs more Billet
  5. Special Ed
    Special Ed
    Exactly....
    This is it in a nutshell. :cool:
  6. SvenOla
    SvenOla
    from Sweden
    S/S , weld , polish ....
  7. fastcar1953
    fastcar1953
  8. Chevy Gasser
    Chevy Gasser
    Possibilities are limitless. I built this grill from salvage yard scrap. It is about 1/2" SS mesh. Used to be some kind of industrial screen, filty and full of crap. Quite a bit of work getting it poshed out. Might have even had tar on it. Another idea is do what Roger Jetter did with his Caddilac. He had 1/8" aluminum sheet cut to match front contour of car. Then he gapped it 1/8" between each section. The most beautiful Caddy grill I have seen. His car is featured in the last issue of Rod & Custom, take a look. Go to the biggest scrap yard you can find and let your mind run wild.
  9. the metalsurgeon
    the metalsurgeon
    from Denver
    Williams wife
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    The '55 Plymouth grille is almost a bolt in for 1952-54 Fords and fits the contours about dead on.
